12-13-2014, 06:59 PM | #1 |
67 door latches in a 60-66?
fact: locking the door with the key only locks the button, not the actual latch
fact: it is hard (if not impossible) to put a power lock motor on the 60-66 latch because of how it locks the 67 inside handle operates like the 60-66, has anyone tried trading out the latch and jamb assemblies to give a latch with a door lock pin? I absolutely want keyless entry, not to use a key, so before I go buy some lock buttons and keys at bowtie bits, has anyone tried this?
12-14-2014, 12:12 AM | #2 |
Re: 67 door latches in a 60-66?
ok I have been looking into it, looks like the 67 latch will replace the 65 latch with a little work, it is slightly longer but has a similar pad for the door button, a similar attachment for the inside handle rod, and has the all important lock rod attachment.
here is the stock 65, note the two mounting screws on the bottom here is the 67, note the two mounting screws are slightly further away, also note the little loop for the lock button rod bowtie bits has the entire assembly for 75 bucks, and they are local, I think a stop is warranted monday. http://www.bowtiebits.com/store/stor...Category_ID=99
12-14-2014, 09:49 AM | #3 |
I have only seen bear claw latches used to upgrade the factory ones, we'll have to see what you come up with.
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
12-14-2014, 01:28 PM | #4 |
I was thinking the same thing. Please let us know what you fine out
12-14-2014, 02:31 PM | #5 |
There was a write-up done a while back on how to modify the stock door latch to accept power door lock actuators. I think it was on http://www.persh.org/Pickup/IdeaPage.htm. When I tried going to that link, however, I'm getting a server error. Maybe someone else knows an alternate location for the write-up. Its what I used on my door latches and it works pretty well. The only drawback is that the button on the outside handle still works and allows the door to be opened to the "first click". It does take a little fabrication but its not too bad.
I'm actually looking to replace my latches with the Altman Easy Latches from Trique Mfg. I spoke with the owner of the company and the latches are are already setup to accept power door locks. The downside to those is the price - $350 a set. I'll dig around and see if I can find the original writeup and post it here.
Steve 66 C10 Short Wide 51 1/2 ton (in storage waiting for 66 to be done) Pickups N Panels Club - Dallas/Ft Worth |
12-14-2014, 02:39 PM | #6 |
01-28-2015, 08:46 PM | #7 |
yeah that just seems like a fiddly amount of work.
but GOOD NEWS! I bought the 67 door latch kits from bowtie bits http://www.bowtiebits.com/store/stor...Category_ID=99 and they will bolt in with only two new holes, and the door lock rod comes up in a perfect spot. If you dont want the lock rod up through the top of the door you can just attach your actuator directly to the latch and remove the rods. The kits come with a new door handle mount and all the rods and even those look to be in the same exact spot as the 66 doors. I think you can even make an external key work with a little work on the rod. All I need now are some door lock actuators and to install my alarm. I will make a how-to thread on this when I put them in but feel free to usurp the credit if you get yours done first.
02-03-2015, 12:01 AM | #8 |
Thanks for posting im going to try it too
02-03-2015, 12:10 AM | #9 |
just a note, you will need three new holes, the upper hole is slightly out of the right spot. I plan to drill the countersink from the old holes, then make the new holes from a template, before welding up the old holes with some flat washers
11-13-2016, 11:12 PM | #10 |
Bump please.
So how did this work out? Is a '67 latch the answer? and what do you recommend for electric actuators?
292 + TKO500 |
03-10-2019, 06:22 PM | #11 |
hillbilly
So before you start. Yes. . . I know im bringing this tread back from the dead. I have the altman easy latches for a 60-63. I would like to install door lock rods like the 67-72 trucks or install a lock/unlock button in the cab. Has anybody done anything like this?
-1962 C-10 |
01-11-2021, 11:28 PM | #12 |
How did this work out?
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis 1964 GMC K10 383cu in/sm465/twin stick np205 1965 Chevy C60 |
