06-08-2019, 06:51 PM | #1 |
column-mount ignition switch
I am putting a new ignition switch on my GM column. What position (all the way rearward, frontward, in-between) should the key and the rod be in at installation? And which of the "stops" should the switch be set on at installation? Any good wiring diagrams would be appreciated as well. I've seen a number of them online, and they are not consistent. Thanks!
06-08-2019, 06:58 PM | #2 |
Moderator
Re: column-mount ignition switch
The GM service manuals and wiring diagrams are in my sig...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
06-08-2019, 10:33 PM | #3 |
Just installed one a few months ago. What I remember is adjusting the fore/aft location on the column so the ignition key would engage the the ACC circuit on one end and the starter motor on the other. In other words, make sure the key will move the switch thru its full range of travel.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
06-09-2019, 10:18 AM | #4 |
Thanks very much. My mistake was tightening it down first, then moving the rod.
06-09-2019, 09:50 PM | #5 |
I'm encountering different diagrams online for the column mount ignition switch. One shows the purple solenoid wire below the pink ignition wire. The other has the solenoid wire on the opposite side (to the right) of the pink wire. Confused!
06-11-2019, 01:29 AM | #6 |
Moderator
The ignition switch wiring colors are not one-size-fits-all... even tho the switch terminal functions don't change over several years the wiring colors can be different. The colors are entirely year dependent.
Download the GM wiring diagrams for your year truck from my manuals post.
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-11-2019 at 01:34 AM. |
06-11-2019, 09:40 AM | #7 |
Thanks, will do. Problem is figuring out exactly what year PO cobbled parts together. Truck is a '56 on an early '70s truck frame, with some Chevelle running gear. I've upgraded the steering, redid the interior including gauges, did some re-wiring, and just swapped the TH350 for a 4-speed, with mechanical clutch linkage. Got immersed in the ignition switch when I put a new CVR starter in place of the old GM unit that wouldn't clear the new 621 bellhousing. When I bought the truck some years ago, a friend told me I should immediately rewire the whole thing. Nah, I said, I'll do it in sections. Bad decision!
06-11-2019, 10:08 AM | #8 |
Moderator
Since this is custom I'd draw your own color diagram for the switch plug. I'd be sorely tempted to draw up a full wiring diagram of my own for something that's Frankensteined together by someone else.
You can magnify the PDF to 200% to 300% or so, select the switch area of the picture, copy to the clipboard, paste to a image editor like GIMP or even CAD software, and print the image on a letter size sheet as a starting point. The GM wiring diagrams will give you the switch function pinout so you can correlate your colors to the functions and move on from there. As tempting as it is to rip it all out and start over it's usually a better idea to do bite size repairs that you can complete in a day or two and document it as you go. The '56 original wiring should be fairly simple and any original 6V wires will be oversize for 12v service.
