12-11-2020, 12:07 AM | #1 |
Body Mount Shims
I replaced my body mounts with new ones from Wes at Classic Heartbeat. I went from 3" spacers to stock height. When I reinstalled the front fenders I had to shim the front tub mounts by 3/8 on one side and 1/4 on the other side to get the gap between the fender and door even.
My question is about the other body mount bushings. How do I figure out how much to shim them? Do I split the difference?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
12-11-2020, 12:27 AM | #2 | |
Re: Body Mount Shims
Full top blazer or bust.... |
12-11-2020, 08:19 AM | #3 |
It looks like you should shim under the remainder enough to "table" (or close the gap I suppose) between the body and the mounts...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
12-11-2020, 12:03 PM | #4 |
Thanks.
12-16-2020, 11:22 AM | #5 |
These trucks were built with a +- tolerance of 1/4", so the number of shims at each point is irrelevant, so having more on one side is probably OK. What determines how much shim you need is the door gaps.
12-16-2020, 07:41 PM | #6 |
The door gaps are good now, and the body mounts are all torqued to spec, so I think I'm OK. Thanks again.
01-04-2021, 11:32 PM | #7 |
What torque specs did you use? also are the rear mounts (lower bushing) compressed a whole lot? See pics in recent post on body bushings
TIA |
01-05-2021, 08:31 PM | #8 |
I looked for the spec sheet I got from Wes in my file (which is really just a drawer in my toolbox) but I couldn't find it. I remember there was a range, and I believe I set my torque wrench at 45 ft-lbs for all but the radiator support bushings. You can see how much the bushings compressed in this pic.
01-05-2021, 09:34 PM | #9 |
Thanks!
01-06-2021, 10:36 PM | #10 | |
