Old 09-05-2020, 10:20 AM   #1
Divine 59
2005 2500HD concerns
Wanted to get some ideas on where to look for this issue.
Truck- 2005 2500HD 6.0 with 4L80E
From a stop there is a very slight slip felt when just pulling away. All shifts in the transmission are smooth.
Current truck has 33,800 miles. We purchased it about 9 months ago from the estate of my FIL. Surprisingly no other family member wanted a 15 yr old truck with 27700 miles on it.
I replaced the carrier bearing, lubed the yoke, and replaced the tail shaft seal due to seepage. Transmission fluid service by dropping pan and changing the filter.
Still has a slip. Is this just how a 4L80E operates? Hoping it is not a torque converter issue.
Thanks for feedback.
My Build Thread http://s95.photobucket.com/user/drop...?sort=3&page=1
Divine 59 is offline   Reply With Quote
Old 09-05-2020, 10:24 AM   #2
Ziegelsteinfaust
Re: 2005 2500HD concerns
My 2018 V6 silverado has the rubberband from a stop light, as did my 2007 4.8. Plus just about every vehicle I ever had has had some rubber band for a stop.
Alot of it has to do with effective gears ratios.
Ziegelsteinfaust is offline   Reply With Quote
Old 09-05-2020, 10:35 AM   #3
Divine 59
Thanks for the reply. I also looked at the u joints. They seem to be okay. The rear end ratio in this truck is 4.10:1
Old 09-06-2020, 02:46 PM   #4
hatzie
Moderator
hatzie's Avatar
Unfortunately it's normal for a slushbox transmission.
The torque converter lags somewhat then begins to hook up and it feels more than a little vague.
You don't really have a locked drivetrain til you clear the lockup MPH at the specified RPM.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 09-06-2020, 04:57 PM   #5
Divine 59
This is the first truck we owned with a carrier bearing. I am relieved to know it is not something serious with the transmission. Hoping this truck will last a while. Based on many comments it should do well into 200k.
Thanks to all for the responses. Chalk up the slip to the carrier bearing/two piece drive shaft.
Old 09-14-2020, 09:46 AM   #6
skyphix
I have two 4L80E's - one in my swapped C10 and one in my Suburban. The torque converters flash up initially and to me, anyway, felt like a slip at first. It just sort of seems like its how a long first gear in a heavy vehicle with a higher stall RPM torque converter is going to be have with a stock-type converter.
Eric
1980 C10 SWB
2003 Chevy Suburban 2500 LT
skyphix is offline   Reply With Quote
