Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 11-15-2009, 10:49 PM   #1
james colbert
trailing arm brackets
Guess that the best way title it. Does anyone make a set of adjustable trailing arm brackets? My truck is on a 67 frame and looking at building a set if I cant buy them. Something to control pinion angle, change bar angle?
james colbert is offline   Reply With Quote
Old 11-16-2009, 12:36 AM   #2
Captainfab
60-66 Nut
Re: trailing arm brackets
I don't think anyone makes them.
Board member and Moderator here on the Racing and high performance forum, Super73 made a set for his '63. I know it is posted here somewhere, but I can't seem to find the thread. You might try sending him a PM
Old 11-16-2009, 04:17 AM   #3
Super73
Super73's Avatar
Correct, I made them from a piece of 2x4 box steel. Drill the holes and then cut 1 side off. Have fun drilling the rivets It will not help you adjust pinion angle, that you need to do with a shim, but it will allow you to get more squat or antisquat in the chassis.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 11-16-2009, 08:47 AM   #4
james colbert
Thats what I needed to know, thanks guys
Old 11-16-2009, 10:21 AM   #5
djracer
djracer's Avatar
It seems like it would have to adjust pinion angle a little. I know the arms are long but I would still think you would get a degree or two from top to bottom holes.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 11-16-2009, 03:36 PM   #6
Super73
Super73's Avatar
Yes, it does adjust pinion angle, but, there is more of a chassis adjustment than pinion angle. For every 1" of adjustment on the LCA hole, there is about 1.1* of adjustment on the pinion. But that 1" of chassis adjustment (that's what I'm calling it for lack of a better term) you could see 5-10% of squat/anti-squat change depending on where you center of gravity height is.
I would not adjust the height of the front hole to compensate for pinion angle. It will open up another can of worms. They should be set up seperately to obtain an optimaly set combo. Hope that makes sense.
Old 11-16-2009, 04:52 PM   #7
dave brode
dave brode's Avatar
Will commonly available wedges work between the rear and arms?
Dave
'71 C-10 medium bed. Pump gas 454" +.030", stock valved 049s, dana 60 w/410s. 12.25 at 108.
dave brode is offline   Reply With Quote
Old 11-16-2009, 06:46 PM   #8
Super73
Super73's Avatar
unfortunately not with out slight modifacation. Standard leaf rears have 2 u-bolts holding the rear to the leafs. Ours use a thick single U bolt. I bought standard angle's and then cut some of the center out of the front and back to acomadate the large single U-bolt.
Keep this in mind, if the joints in the front had zero deflection, squat will promote negative pinion angle, and antisquat will promote positive pinion angle. Knowing what the suspension is doing under load allows you to set it up correctly.
IMO (until proven wrong) pinion angle has nothing to do with traction (bite) but rather helps with efficiancy under full load (putting all your power down). The goal is to get pinion angle to a perfect zero degrees under full load for best acceleration. Where your going to see the biggest change on pinion angle is at the starting line. This is why a proper pinion angle shows a better 60'
