09-23-2012, 09:48 PM | #1 |
electric choke power source
Anyone have suggestions on where to get power for my new Summit carb electric choke? I have read that the fused ignition is not the best idea because the choke will heat when the key is in ACC. I am almost finished with an intake/carb/dizzy upgrade- anxious to get these last few details buttoned up and fire it back up.
Also going to add an aftermarket tach- wondering where the best place might be to tap 12v for it? |
09-23-2012, 11:02 PM | #2 |
Re: electric choke power source
Find an unfused plug on your fuse box under the dash. Should be a couple there.
They're usually only 12v when the ignition is on. Check with a test light to be sure. |
09-24-2012, 02:20 AM | #3 |
Grandpa in the rustmobile...
^What he said.
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
