Old 03-08-2015, 05:11 PM   #1
Metalshapes
Metalshapes's Avatar
'79 K5 exhaust question
Hey fellas, I acquired a '79 K5 that is 99 percent stock except for the headers and some cobbled up hack job of true dual exhaust that the PO put on. I want to go back with a stock layout so I need to know which side the "Y" pipe collects on, I'm thinking the drivers side because of the differential and front driveline. Also, in '79 did they have the dual exit behind the drivers side rear tire or was it just a single? Pics and advise are greatly appreciated.
Rally 'round the family....with a pocket full of shells.
Metalshapes is offline   Reply With Quote
Old 03-08-2015, 06:58 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: '79 K5 exhaust question
Wish I could help. I've only had one with stock exhaust and it was an 83. It did have the Y-pipe, muffler, and tail pipes on the drivers side. For awhile anyway, I'm a duals junkie.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 03-08-2015, 09:39 PM   #3
Metalshapes
LOL I know what you mean, and normally I am also but this one is a little different, the dash has not been cut for an aftermarket stereo and there is headers, it even has the original factory floor mats, other than that it has not been messed with at all, so I figured I would do this one justice by putting it back the way it came, manifolds, single exhaust, and the factory stereo if and when I can find one.
Old 03-08-2015, 10:37 PM   #4
68Timber
68Timber's Avatar
Exhaust seems to be the one thing you can always get a pass on if you skip going back original but I can appreciate making it 100%. Post up some pics!
John
74 Honda Z50 build
Old 03-09-2015, 02:03 AM   #5
Metalshapes
I'm in the process of laying out my resto thread, fyi it will be pic heavy, it will also feature in depth techy stuff, from the easy all the way to the hard.
Old 03-09-2015, 11:09 AM   #6
K5owner
Honestly a good single exhaust with quality cat (if so equipped) straight through muffler (magnaflow) and 2 3/4 to 3 inch piping will flow well and sound good while not killing performance like the factory exhaust did.
K5owner is offline   Reply With Quote
Old 03-09-2015, 12:11 PM   #7
mattcrp1
mattcrp1's Avatar
I am in the process of doing my exhaust on my 76 truck. I went to my local muffler shop and they have a "universal" type muffler back pipe for a reasonable price, less than summit delivered, and it is a 3" mandrel bent pipe.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 03-10-2015, 03:27 PM   #8
Metalshapes
sweet!!! I just got back from my exhaust shop and they're by far not the cheapest in town but they do excellent work, they hit me with a $1000 ish price tag, custom from the manifolds back and guaranteed that if I need to I can take some of it out if I have to remove trans/transfer case.
Old 03-10-2015, 03:34 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
Walker does make a dual (2.25)setup (both sides)used on my 78 and some others make the full length kits.
some rusty shots of my 79K
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-10-2015, 03:46 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
thats about what my 79C custom bent cost.
2.25 pipe to H to flowmaster 40s
I removed "stock" at home,installed the "new"manifolds,and straight pipes,drove it in.
I'm told some muffler places can't remove the "cat",but will fix the "leak"
John
Old 03-10-2015, 03:52 PM   #11
motornut
78K & 79C Jimmys
motornut's Avatar
the duals on the 78 K,now with turndowns after the Cherry bombs
John
Old 03-10-2015, 04:01 PM   #12
68Timber
68Timber's Avatar
Some of the exhaust prices I see quoted online blow my mind. Two or three weeks back I paid $180 for custom duals from the manifolds to the back with full tail pipes and 2 1/4" aluminized pipe. I provided some lightly used turbo mufflers. When I was a teen, every muffler shop in town would run duals w/cheap mufflers for $99.95 out the back, hasn't gone up much at all.
John
74 Honda Z50 build
Old 03-11-2015, 02:20 PM   #13
kevinr1970
x2
I was quoted ~$1000 for duals on my crew cab 4x4 WITH stainless headers with massive flanges, and pretty much whatever muffler I wanted (FM,MF, etc).
I priced out the exhaust kit, mufflers, headers through Summit / Jegs and with a mandrel bent kit it was about the same price, about a $100 less for non-mandrel kit.
But the with the shop it was installed!
As for this post, I can understand a super low mile original, or something that is going to be shown as all original, but I think at this point (and cost) I would go with a quality headers and true duals.
$.02
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
