Old 07-21-2018, 09:29 AM   #1
djnordeen
60-66 crew cab wheel base
Hello,
Anybody have wheel base specs for the Crew Cabs?
Any other crew cab specs, like cab mounting dimensions?
djnordeen is offline   Reply With Quote
Old 07-21-2018, 10:35 AM   #2
66Gilbert
1966 Crew Cab & 4X4 Fanatic
66Gilbert's Avatar
Re: 60-66 crew cab wheel base
I can only speak for my Ambruster Stageway Crew Cab. Most were built on a long bed chassis wheel base of 127" and had the bed cut down to a funny looking short bed. My 1966 Crew Cab had the frame extended by one foot and has a wheel base of 139" and had the bed cut down to an out of proportion 6.5 foot short bed. Not sure if they were ever made but a Crew Cab with a regular short bed (bed not cut) would have had a wheel base of 148.5". A long bed Crew Cab has a wheel base of 160.5".
66Gilbert is offline   Reply With Quote
Old 07-21-2018, 10:43 AM   #3
66Gilbert
66Gilbert's Avatar
Here is a picture of mine.
Old 07-21-2018, 10:43 AM   #4
Clyde65
Clyde65's Avatar
Like 66gilbert said, most were 127” WB.
If you need a crew, with full long bed, I can measure my dad’s.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 07-21-2018, 02:49 PM   #5
djnordeen
I have a 1994 K3500 Chevy Crew Cab 4x4 SWR, that I am going to replace next year with a newer 2006 or 07 K3500 Chevy Crew Cab 4x4 SWR.
Wanting to do a project Crew Truck in the mid 60's.
My wheel base is 168.5"
Thanks!
Old 07-21-2018, 11:19 PM   #6
Captainfab
60-66 Nut
A '88 and up frame would not be my choice to mount a '60-'66 body. You are in for a LOT of work.
Old 07-22-2018, 08:25 AM   #7
djnordeen
Yes I understand that.
What I am thinking is to merge the two bodies together. Use the 94 cab on the inside, floorpan, firewall,roof and rear. Then fab the outer 64-66 "skin" to replace the 94 "skin".
Old 07-22-2018, 05:35 PM   #8
djnordeen
Clyde65 That would be great if you could measure your dad's Crew.
