10-10-2011, 07:19 PM | #1 |
68 to LS1 motor swap Questions.. HELP plz !!
Ok.. been doing body work for a long time.. almost done, but getting close to dealing with other issues.
Have a few questions I can't seem to find answers on. Starting with a 1968 GMC.. Installing a 2002 5.3L Vortec & 4L60E Tranny. Radiator.. Need to get a new one.. do I order a 68 like orig, or a 2002 and modify mounts? Will upper and lower radiator hose fit if I use 68 orig style radiator. The O.D. of water inlet / outlets look like they do not match up. Power Steering... Using pump that came with 2002 motor.. but using 1972 Power steering box, What, and where do I find the proper fittings to match up the new hose to old style steering box ? Fuel... I ditched the in-cab tank and welded up the hole. Want a under bed style tank, .. bought the kit from Classic Truck Parts, and already returned it a week later. It is too deep for a lowered truck. Too deep / low to the ground for my style. Is there a shallower one ?? Fuel pump.. which one / system is best ? This motor has a cable system.. do I need to build modify something to work ?? Transmission... Gonna use the 4L60e that came with motor. Do ya have to create a shift linkage set up to work with column shift ? How do you address overdrive ?? How do you engage it if there is no button on column shift ? Speedo ?? see next item !! Guages... Do / can you use stock gauges ? Will fuel gauge hook up normally ? Speedometer ? Oil pressure ? Ignition switch ??? Do you need a check engine light on dash ?? These are all the questions I know about.. I am sure I will find more. You all helped me big time on the engine mounts, and the header situation, and I greatly appreciate it. I am trying to get all the body work done so I can get it painted, and then tackle all of the above fun times I have in the future !!! Thanks |
10-10-2011, 10:42 PM | #2 |
Has more rust than truck...
Re: 68 to LS1 motor swap Questions.. HELP plz !!
Most if not all of your questions are answered in the LSx FAQ:
http://67-72chevytrucks.com/vboard/s...d.php?t=456787 Lots of reading but well worth it! |
10-11-2011, 02:37 PM | #3 | ||||
meowMEOWmeowMEOW
I actually just cut the old fitting off of the hose, and re-flared the metal end on my newer hose to accept it. Quote:
I used my stock ignition switch and tumbler, hooked up to the "new" ignition. Works fine. Mine isn't a 68, but my 66 should be very similar.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
10-11-2011, 02:41 PM | #4 |
Temp sender will be different, also you will need to to drill out your pass side head to fit the temp sender of your choice.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
10-12-2011, 11:25 PM | #5 |
meowMEOWmeowMEOW
I should also mention you can cheat and run something like a scangauge as i did. Its kind of a shortcut to alot of gauge info, without all the gauges. My temp is read through the pcm, so i didn't have to drill the head.
As for the gas gauge, any one would work fine, just make sure it uses the same resistance sweep as your sending unit.
10-13-2011, 11:29 PM | #6 |
I run a 02 vette radiator because you can get it for a 100 bucks or less and it has a oil cooler and tranny cooler built in. its smaller and takes a little trimming and fabed brackets. I run a camaro tank under the rear stock intank truck pump. make my own lines check fuel line thread. I would wire it up with a check engine light and gm plug. you normally need to cut the top radiator hose if you run the truck style cause its to long you can get a connector that will accept a mechanical temp gauge to run there. the oil sensor in the back of the manifold can be removed. break off the top and drill and tap for 1/8 pipe and run any mechanical oil press gauge. speed o needs to be electronic. tach needs to be programmable to 4 cyl caus thats what the pcm puts out. I wired mine my self from the lt1 swap site and it fired right up no problems. I sent my pcm to wait4me performance to be tuned and vast removed 75 bucks. there are better options . I live 30 min from texas speed when i do the cam swap they will tune it better Im sure but I have had no issues with the tune it has and it is turned up as much as you can for a stocker. I run a b&m pro ratchet they make a kit that bolts to the tranny and shifts all 4 fine.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
10-13-2011, 11:32 PM | #7 |
also camaro e fans work great on the vette radiator. a new truck radiator will probably be too tall. you will need some sort of radiator expansion tank mines off a cavilier. Im not running ps or ac I have a smaller belt rerouted
