04-27-2018, 06:39 PM | #1 |
Rear view mirror mounting
I know this isn't rocket science and admittedly, I'm not the handiest of wrenches.
My original mirror was mounted with just three screws but the mirror itself was loose as all hell. I broke the screw trying to retighten it. So I got an aftermarket LMC one and tightened it, only to have the three screws that are supposed to hold the mount in place not grab into anything. So I know of no way to get a nut back there or any trick to use short of using some kind of super glue and hoping it holds. Right now, I've gotten really good at only using my side mirror. Any ideas? |
04-27-2018, 06:49 PM | #2 |
Re: Rear view mirror mounting
Stick a piece of mechanics wire in the hole, then put the screws in,cut of the excesse wire and put the cover back over.
04-27-2018, 06:52 PM | #3 |
Thanks, I'll do that. I'm guessing you mean bailing wire or is there actually something called mechanics wire?
04-27-2018, 07:01 PM | #4 |
Bailing wire is the same,just don't go to thick on the wire.
04-27-2018, 07:02 PM | #5 |
Ok, will do. Thanks again
04-28-2018, 12:01 AM | #6 |
Or you could do like the MY 1972, with a glue-on bracket on the inside windshield. Not a fan of this installation. It wobbled bad. I've reversed the process on one truck already.
But if worse comes to worst, it's an option. I'd try the wire trick first.
04-28-2018, 12:07 AM | #7 |
I used a glue-on-the-glass mirror. It's an aftermarket one.... But styled like a much older mirror. Has the chrome day/night knob and everything.
I welded up the holes in the roof during the restoration. I prefer the mirror on the windshield. You could just buy larger self-tapping screws, and open up the holes on the mirror mount if you really want to keep it looking original... Just my thoughts. |
04-28-2018, 02:33 AM | #8 | |
I've found it's difficult to find new tap screws that fit our old Chevys. I believe that's why on occasion there's some dispute #8 Vs #10. The difference may be various thread counts. If a new screw manages to secure, there's a good chance the hole will be too large for the "correct" one.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
04-28-2018, 07:58 PM | #9 |
My 72 is windshield mount so I went to the self serve scrapyard and ripped on off a random GM windshield and glued it on.
04-28-2018, 08:22 PM | #10 |
Gently tapping the metal around the screw holes until it's flat will usually push the metal back in far enough that a sheet metal screw will hold.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-29-2018, 06:29 AM | #11 |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-29-2018, 09:32 AM | #12 |
I tried the "glue" on the windshield, not once, not twice, but 3 times and the mirror kept falling off. Yes, I cleaned the windshield, and yes I used the correct side to glue on, so I opted for the "original" mounting and screwed the mirror on. Works great, and looks great.
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
04-29-2018, 08:16 PM | #13 | |
Damn this traffic jam How I hate to be late It hurts my motor to go so slow Damn this traffic jam Time I get home my supper'll be cold Damn this traffic jam Well I left my job about 5 o'clock It took fifteen minutes go three blocks Just in time to stand in line With a freeway looking like a parking lot - chorus - Now I almost had a heart attack Looking in my rear view mirror I saw myself the next car back Looking in the rear view mirror 'bout to have a heart attack I said - chorus - Now when I die I don't want no coffin I thought about it all too often Just strap me in behind the wheel And bury me with my automobile - chorus - Damn... Now I used to think that I was cool Running around on fossil fuel Until I saw what I was doing Was driving down the road to ruin
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
