Old 12-07-2016, 05:06 PM   #1
rockosocko
Boring CAM journals.. Is it worth it?
Got a buddy that gave me a '85-87 short block and as I was stripping it down, I noticed that 3 of the cam bearings look like almost 3/4 of the circumference of the bearing ID wasn't even touched! (?)
Is it worth getting it bored or just look for another block?
I know that they offer over-size bearings, but also have been told NOT to worry about it. That it really doesn't matter that much.
Also, I've read TONS of articles about a "Cam Shoot-out" where they just pop multiple cams in and out without a problem.
Just a little concerned about the oil pressure loss at that point.
What do you guys think?
Errol
rockosocko is offline   Reply With Quote
Old 12-07-2016, 08:50 PM   #2
crazy longhorn
Fabricate till you "puke"
Re: Boring CAM journals.. Is it worth it?
Which 3 bearings, looked "funky"? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-08-2016, 02:10 AM   #3
James the III
Errol
What part looks "touched" the bottom, where the spring pressure is pushing down on the cam??
most cam bearings don't look touched..
todays higher cam lifts and springs pressures push on the cam more , dry start ups.. no or low oil psi will cause the bottom to look worn..
James the III is offline   Reply With Quote
Old 12-08-2016, 02:22 AM   #4
crazy longhorn
Nobody else wants to play?The camshaft is 1st thing that I stick in a build....it needs to turn like butter, with a little 10/30 on the journals. If it does that, I dont see an issue. Then you lay the crankshaft....make sure that it turns like butter.Watch the pistons going in(smoove), no fight....twist that shortblock over....no fight, she rolls smooth. Check valve to piston clearance. Bbreak that bioch in......then run it like you stole it! longhorn
Old 12-08-2016, 09:06 AM   #5
GRX
GRX's Avatar
Pretty normal for the bottom part of the cam bearing to exhibit wear considering there is over half a ton of spring pressure forcing the cam downward.
If you think the cam journals are out of alignment the block may have bigger issues. Have the main saddles checked. At this point you may as well source a new block. 1st gen are easy to find.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 12-08-2016, 12:47 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The cam journals are fine. The bearings were doing their job like they should have.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
