its all about the +6 inches
very low buck frenched side marker mod
First and foremost, I can not take credit for this mod.
Last year when Mike and I were at Brad's, I noticed this mod on Brad's new 68. After looking at it I figured it out and have been wanting to do it since. It took a few months to get to it, but now I have done it. First, Brad's truck. His markers grabbed my attention as soon as we got out of his 67. ![]() As we all know the side markers on these trucks stick out like the eyes on those gold fish. You know, the ones that you always wonder how it is they don't snag them on a rock... yeah, like that. ![]() This mod is simple. The cost is minimal, and the tools needed are low level too. Most, if not all of us, have the tools needed. No sawszall needed (i know... bummer) Here's all I needed. A milk crate on a 4 wheel dolly for a seat. Adjust height acording to the height of your truck. I used a cut off wheel, and then normal everyday hand tools... screwdrivers channel locks and super glue. A dremmel tool will work if you don't have air tools. Don't forget the safety glasses, sparks will fly, and they always find a way to your good eye. ![]() Step one, grab a #2 phillips screwdriver and remove the lenses. ![]() If you don't already have the delux markers, run to the junk yard or parts vendor/swap meet, and get a set like these. (junk yard guys, don't forget to look on 70's and 80's vans.... EXACT same piece) I got mine off a 72 GMC Mike and I scrapped a couple weeks ago. ![]() once you remove the lens, you'll need to remove the little threaded clip. I can't remember what the heck it's called, but it is no longer needed. So when they shoot inside the fender or bedside, don't worry about crawling around looking for them, just let them fly (glasses on). Once they are removed, you'll need to do some light trimming. Before; (paper towl placed in the hole for contrast so you can see better in the photos) ![]() and after; ![]() You don't need to trim it quite as much as I did in this pic. You just need it narrow enough to fit between the upper and lower lens of the marker. You'll also notice, I tried to keep the verticle cut in line with the stock vertical line. Those of us with beaters have the upper hand here, it is easier to paint the parts to match primer than it is to color match to a painted fender. Mine is close enough to this semi gloss spray bomb. A painted truck could just have the nubs sticking out done in flat black to match the center of the lens, or, if this is pre-paint, then paint the center of the lens body color. Just remember to paint the head of the screws the same color (unlike what I did on this one) to help hide them. We'll get to the hardware in a moment. ![]() The rear proved to be a little tricky. Due to not a whole lot of space between the inner and outer walls on a fleetside bed, I had to create some room. A hammer and a brass drift made just enough room, however, the damage done to the inside was minimal. On a beater, it won't even be noticed. On a glossy pretty inner bed, you may have to get creative and get a better solution. I also had to mount the lens upside down, but hardly anyone will notice. You can even mount the front ones upside down if you are totaly OCD like myself. (I plan on flipping them soon, it bugs me) ![]() On the drivers side of a burb, access to the backside of the panel involves panel removal inside. I can only assume blazers are the same. Pick ups have the advantage here... esp stepsides. The hardware used is not the stock screws. You'll need small nuts and bolts. I had some laying around so i honestly couldn't tell you the size. You have room to play here, they can be smaller than needed, as long as the head doesn't fall through the hole in the sheetmetal, and as long as the bolt will fit through, and reach through the lens. On vehicles where backside access is restricted, you may want to glue the nuts on the backside. A few things to pay attention to, do not get super glue on the lens face, it will fog and ruin the lens, also, don't get it in the threads of the nut. Keep the glue away from painted surfaces, and don't glue the parts to your finger. You'll look like an idiot. ![]() Slip the lens through the opening, then while reaching to the backside, position it into place, Mount it with the nut on the backside of the lens. The fronts can be done quite easily by one person. I have batteries on both sides under my hood, and still managed to do it myself. The rear can be a little tricky, plug the light in, then put the lens through the hole, then reaching up from underneath, guide it into the hole, and then secure with the screws. Last edited by Longhorn Man; 09-21-2009 at 10:38 PM. |
Re: very low buck frenched side marker mod
If you get it right, you'll have frenched... or at least semi-frenched side markers like this;
![]() ![]() I never got photos of the rear ones. The actual end result is much better in person, my crappy underlit photos aren't doing it justice. On a scale of 1 to 10, I would rate this on the lower end, quite easy in reality. Maybe a 4. As always, please leave feedback here in the thread. Let me know if I am on to something... or just on something! |
Old Skool Club
![]() Join Date: Jun 2001
Nice documentation for anyone who is interested. Nice look, too.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Old member
This maybe do able on the 71. Thanks!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Eat My Rust
I've got freetime this weekend, I'll give it a shot. Need to repaint my markers anyways.
I like the look though! |
This is definitely FAQ's worthy. Nice write up Longhorn!
One day.....
Great info! Just might do that mod.
DZL1. |
Size Matters
I would love to see some better pics of the finished product if you get the chance.
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ![]() ![]() Last edited by Longhorn321; 09-22-2009 at 12:15 AM. |
Eat My Rust
I've decided to do it, it's dirt simple looking at it on my truck. I'll buy the paint and some cutoff wheels tomorrow and get at it after classes..
VA72C10
![]() Join Date: Mar 2008
Nice writeup....making me rethink completely shaving mine now.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
I got ya'... That's a clever fix. I still think I like the van markers better, but that's real slick!
Tony Johnson -- '71 Blazer w/L-31 Vortec 350, SM465, NP205, performer intake, edelbrock 1406, HEI, 4" lift, Boyd EFI tank, Vintage A/C My Blazer -- |
BlahBlahBlah
I like that mod, I had forgotten about it. I think Livrat came up with that when he did Brads truck.
That is a nice custom touch.And it can always be put back to original.I never thought of the stock ones as sticking out a whole lot.At least the factory stamped recesses for them.I have wondered what keeps goldfish eyes from popping out,though.
sooooo?? Andy when are you coming to South Florida.....
![]() ![]() great mod!!!!! Will probably do it and I have a set of lenses from one of the clunkers I sent to the crusher so I might use those instead for domething different,,,,will see....thanks for sharing..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#15 |
more ideas than money
Looks great! Thanks for taking the time to share it with us.
![]() 1948 Chevy 3100 5 window 1966 Chevy C30 Dually 1967 Chevy K10 1972 Chevy K20 1972 Chevy C10 1972 Chevy K5 Blazer 1987 Chevy V10 2003 Chevy Suburban |
#16 |
Member #1049
ANDY... you stole my secret!!...
I did that mod for the first time on my 70 2WD Blazer about 25 years ago.. BTW.. good write up!!... thanks for sharing, I just never seem to get the time to do them... |
#17 |
Member #1049
Here is a couple more pics of the mod...
#18 |
Restoration Virgin!
Livrat....GREAT Mod!!!
This deserves to be in the FAQ section.... Thanks for being the loud mouth and Nice write up LHM!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 09-22-2009 at 05:05 PM. |
#19 |
Livrat... this idea of yours is awesome! I was totally geekin over the ones on Brad's. I wasn't kidding either, I noticed it AS SOON as we got there from the airport last year. At first I thought they were forebird lenses, but they looked too good.
I was thinking this was your mod, but I couldn't remember 100% if it was you or not. You deserve all the credit... it's an awesome idea. To everyone else... Livrat deserves the credit... I'm just the one with the big mouth! |
#20 |
Eat My Rust
Got the stuff, will start tonight if I've got time.
About $7 in hardware, $3 in paint, and a 13 dollar dremil kit be cause I lost all my bits and cut-off wheels. hardware was expensive because I had to be fancy and get the rounded allen wrench screws that were 1.30 a pair or what ever. Last edited by texanidiot25; 09-22-2009 at 04:12 PM. |
#21 |
printing is my trade
thanks for putting this up here. I'll give this a go when I get some free time.
Jojo's '70 stepside build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=344184 |
#22 |
Eat My Rust
This is awesomly easy. Got one corner done in under 20 minutes from the time I unscrewed the light til having it mocked back up:
![]() ![]() ![]() ![]() Last edited by texanidiot25; 09-22-2009 at 07:05 PM. |
#23 | |
That is cool and low-buck too. The only thing I would change/add is to black out the screw heads too....especailly on the black truck, but it would improve any of them. The space between the lenses is black anyway?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
#24 |
Cool Truck
Pretty neat, but I am leaving mine stock.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
#25 | |
Eat My Rust
If I get motivated, I'll talk to my old cad teacher and see if he'll let me draw up a little trim piece that goes over the cut tabs and the newly created pocket, to tie things together and hide the cuts. ![]() ![]() ![]() ![]() ![]() mo' pics coming Last edited by texanidiot25; 09-22-2009 at 09:26 PM. |
