Old 04-28-2023, 09:59 AM   #1
BanjoDude
Junior Member
R44 or R45S plugs??
Hi guys! My manual recommends R44 plugs for the 307 in my 69 C20. I'm running stock ignition with points. The parts store sold me R45S plugs for it. Is there any issue with that, or should I go back and get the 44? Thanks so much as always for your help!
Wes
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again.
"For just a little more, you can do it yourself!"
BanjoDude is offline   Reply With Quote
Old 04-28-2023, 10:11 AM   #2
duallyjams
duallyjams's Avatar
Re: R44 or R45S plugs??
The R45s is a hotter plug. My 327 burns oil so I changed from the R44 to the R45s to help from fouling the plugs.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-28-2023, 11:14 AM   #3
kwmech
It is hotter (as mentioned) and also comes with an extended tip ( S designation). What do the old ones look like? With todays crummy fuel I'd say stick with the 45s
Old 04-28-2023, 11:43 AM   #4
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
That's what I'm running in my 283
67 C10 283 T5 swapped longbed fleetside = wife's daily driver
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 04-28-2023, 12:06 PM   #5
BanjoDude
Junior Member
I plan to pull them tonight and have a look at them. I have no idea what's in there and how old they are.
Old 04-28-2023, 12:13 PM   #6
Wrenchbender Ret
The extended tip plug came out in the late 50's early 60's for o-head valve engines. All the manufactures soon went with them. They are a big improvement from the recessed tip plugs. The R45S plug is only one step hotter then the R44. That is the best way to go. They should not be used in flathead engines.
George
Wrenchbender Ret is offline   Reply With Quote
Old 04-28-2023, 12:30 PM   #7
697498chevy
Just checked and I put Autolite 85 plugs in my '69 307 last time . Was that a bad choice ? Seems to run ok . Thanks !
697498chevy is offline   Reply With Quote
Old 04-28-2023, 02:47 PM   #8
kaycee
kaycee's Avatar
I used those in my 350 and they were good plugs ,I may switch back next time in my 327,Im running the 44 in them now.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327
kaycee is offline   Reply With Quote
Old 04-28-2023, 02:51 PM   #9
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The R45S's should be fine in the 69 307 heads. The older motors tend to lose compression and use a little more oil so going one number hotter is probably a good move. I run the same plug in my 427 BBC w/69 closed chamber heads...I found some ACDelco R45S plugs on ebay for a $1 a piece. They were NOS plugs made in the US, they're not anymore. Hard to find US made spark plugs these days and when you do find them they're hot cheap! I'm running Pulstar plugs in my bike... http://toms427impala.info/CT/ACPlugI...Extended%20Tip
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-28-2023, 03:45 PM   #10
BanjoDude
Junior Member
Interesting. Two of the plugs I got are made in the USA, two made in Mexico, and four made in China. Should I take them back and at least get all 8 from the same plant? If there's a significant variance, it seems like that could have a couple of cylinders running hotter than the others...
Old 04-28-2023, 04:25 PM   #11
697498chevy
Thanks , Kaycee !!
Old 04-28-2023, 09:17 PM   #12
BanjoDude
Junior Member
Anyone have thoughts on mixing and matching the same model plug from different eras/plants? Seems like it would essentially be the same as mixing the same plug from different brands, which I know is not a good idea. Perhaps I should return them and buy a set of NOS off ebay?
Old 04-28-2023, 09:45 PM   #13
Steeveedee
Who Changed This?
Steeveedee's Avatar
Pretty sure that the product manufactured on different continents is going to be different. Might have not been the case in years past, but now, who knows?
~Steven
Simi Valley, CA
Old 04-28-2023, 10:32 PM   #14
PbFut
I doubt the difference in manufacturing plant will make such a difference as to be worried. You are going to have a bigger variance in cylinder compression and oil consumption and old plug wire in each hole than you are spark plug difference.
The plugs are not likely going to affect a 100 mile plug read. I would use what you got. Look them over at 100 miles and go from there.
PbFut is offline   Reply With Quote
Old 04-28-2023, 11:52 PM   #15
Ironangel
Ironangel's Avatar
I bought him out, he only had 26, I just tuned up the fleet... Different plugs wont hurt a thing. These late model electronic dudes have O2 sensors on every head pipe can probably see the difference, maybe? That charge and piston dont know what brand just set the fire...
"Two Seventy Two's"
02 3/4 ton Express
