07-21-2021, 02:08 PM | #1 |
Master Cylinder Manual Disc Brakes
Greetings! I am going with 4 wheel disc brakes on my 1970 C10. I currently have manual brakes. What master cylinder is everyone using to run manual disc brakes? Thanks.... I am in the research phase....
1989 5.0 LX Coupe 1989 Saleen #243 1969 C-10 Fleetside 1966 Mustang Coupe GT 1965 Fastback Mustang 1951 F1 Truck |
07-21-2021, 03:51 PM | #2 |
Re: Master Cylinder Manual Disc Brakes
You are way ahead to buy a complete engineered kit from someone like Wilwood
https://www.wilwood.com/ |
07-21-2021, 07:02 PM | #3 |
Most guys run a 70’s corvette master cylinder. Make sure to get one for manual brakes. They are inexpensive and work well.
07-22-2021, 08:46 AM | #4 |
I ordered a 1.0 Bore master cylinder from a 84 C10 with manual brakes. Also ordered an adjustable prop valve. Going to trying this route before I buy a complete system. I do have Wilwood on my 65 Fastback.... easy to go crazy with their solutions....
07-22-2021, 08:53 AM | #5 |
07-22-2021, 09:37 AM | #6 |
Just be sure to make sure you have the correct cylinder bore diameter for the calipers you are installing. That is the key for running manual disk brakes (too big of a diameter, leg day every day and if too small, not enough throw in the peddle to fully engage brake calipers). I'm doing the Wilwood route currently and they had to size that for me. Since you already bought it, I'd definitely see where that 1" bore puts you.
1970 Chevrolet C-10 w/355sbc 2010 Silverado Daily Driver 1971 Mercedes 280sl project car |
07-22-2021, 11:53 AM | #7 | |
