Old 06-13-2019, 08:45 PM   #1
Houston Ben
Houston Ben's Avatar
Drum brake backing plate
Hi all, found my rear drum backing plate has groves/gouges where the shoes ride. Do I need to replace the backing plates?
Thanks for any help.
1986 C10, 2011 5.3 w/6L80, 3.42 w/ Detroit TrutTrac
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=584532
Houston Ben is offline   Reply With Quote
Old 06-15-2019, 05:53 PM   #2
WyattTX
Re: Drum brake backing plate
Unless it is rotted or beaten beyond use, I would re-use it. New shoes, new wheel cylinders, and new springs are all that is needed in most drum rebuilds. If you can, you should post a picture, so we can give you a better judgement.
WyattTX is offline   Reply With Quote
Old 06-15-2019, 10:55 PM   #3
Houston Ben
Decided to go rear disc
