04-27-2017, 09:10 AM | #1 |
LMC Tach for 1987 Model?
I have been looking at the LMC Tach for some time, would love to have that factory looking tach in my dash. I have read some of the write ups on here about installing one into a cluster and how to relocate the fuel gauge.
One big mystery I have stumbled into is if this will even work on my truck - I have a 1987 model with EFI. I have read somewhere that this model year cannot have a tach, because 87 EFI trucks have speed sensor (VSS) feedback needed for the factory EFI computer. I wouldnt think the VSS would be affected by the tach, but i have never tore into a cluster before so maybe its on a spot where it wont work? If anyone has done this on an 87' model, I would appreciate input. Thanks! |
04-27-2017, 09:29 AM | #2 |
Re: LMC Tach for 1987 Model?
My '87 TBI truck came from the factory with the tach cluster.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-27-2017, 09:31 AM | #3 | |
04-27-2017, 09:45 AM | #4 |
Sounds like its a non-issue then - SCOTI - did you cut a hole in your stock cluster and run wires over to the new fuel gauge spot like I have seen some do - reusing the stock printed board? Or did you handle it differently?
04-27-2017, 11:20 AM | #5 | |
I used the LMC small fuel gauge & a 7k tach w/both using the later year models font so everything matched the remaining OE gauges.
04-27-2017, 11:55 AM | #6 |
I like the look of that 7k tach - where did you get it at? - the LMC ones are all 5k tachs.
How difficult would you say this install is? I know its always a pain to take the dash apart for me - seems like it takes a good amount of time to get it all out and then back together for me. |
04-27-2017, 12:06 PM | #7 |
Mattchu60, I'll be watching this. Please post the success you have. I have a 91 cluster for my LS conversion and would like a tach and relocate the fuel gauge as well. Good Luck, Mike.
Instagram @HomeBuiltC10s Dads 79 GMC Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=642929 1978 Silverado Build http://67-72chevytrucks.com/vboard/s...d.php?t=756016 |
04-27-2017, 12:33 PM | #8 | |
Be advised though, they sent the tach & the 4 gauge cluster assembly. But, the font style for the 2 upper gauges were 81-87 while the lower 2 were 73-80. I was kind of pissed about that. So I ordered the correct font fuel gauge & did it that way. That 4-cluster set-up is still sitting in the box on a shelf.
04-27-2017, 02:20 PM | #9 |
Ok - I have seen these before - I don't really like that you have to order the new tach along with the 4 gauges as one unit, but i suppose it is convenient for some to do it that way vs buying a stand alone fuel gauge.
The 4 gauge pod seems to have the correct lettering in the picture for the bottom ones - but something does look "off" about the lettering, almost like its too small or something. maybe it would look fine once installed. |
04-27-2017, 02:56 PM | #10 |
Here's what the factory setup looks like (in terms of font) -
K
03-10-2020, 01:30 PM | #11 |
Does anyone sell a kit that allows this upgrade to a non tach cluster?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-10-2020, 02:13 PM | #12 |
Brothers or LMC are the only ones I've seen. I know LMC has them listed as a back-ordered item.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 03-10-2020 at 02:21 PM. |
03-10-2020, 05:07 PM | #13 | |
Pretty pricey....
03-10-2020, 06:23 PM | #14 | |
03-12-2020, 12:55 PM | #15 |
Usa1 parts has the same set up as well.
http://www.usa1industries.com/produc...cat=668&page=1 I am building my own as well. Early mock up stages.. https://ibb.co/c8TD9Rq Last edited by Factory Guy; 03-12-2020 at 01:00 PM. |
03-13-2020, 11:31 AM | #16 |
Sorry I waited on purchasing a 7K tach, Looks likes the new ones are gone forever.
Desert |
