Old member
71/72 tilt wheel & horn video
I just finished installing a factory tilt wheel on the 68 stepper. I did a video of the wheel install and horn pieces so if your need info on it it's all here. I do raw video's no editing.
A few points to make. The turn signal cam has to ride on the copper spring loaded piece for the horn to work so if the wheel isn't all the way down it want work. There are 2 different horn retainers for these trucks depending on which wheel you use for the truck. You can see the differences in the pictures. ![]() https://www.youtube.com/watch?v=fI515M7mgVo
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
![]() Join Date: Sep 2016
Re: 71/72 tilt wheel & horn video
Great video, This is something I will be working on soon. Thanks for sharing.
