Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 05-05-2015, 12:30 PM   #1
GRADYS Performance
GRADYS Performance's Avatar
Limited Slip Differential.
Anyone have thoughts on using a factory Posi in a 7.5 28 spline rear end compared to an aftermarket Posi or Tru-Trac?
GRADYS Performance is offline   Reply With Quote
Old 05-09-2015, 05:29 PM   #2
mrolds88
Re: Limited Slip Differential.
Yes I have thoughts. Stock late model "posi units" are anything but. They use a weight system to lock the side gears. around here they are called "whizbangs". The design allows for one tire to lose traction and start spinning. Thats where the weight system comes into play. the shaft the weights are on starts spinning and then engages the locking parts. so after this when the lock engages it shocks the other tire and in my experience it usually starts to spin too. I would hold out for an aftermarket plate type posi. I grabbed the image off of ebay
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
