Old 01-26-2011, 03:38 PM   #1
kiles_2001
suspension swap
Hello all I am pretty new to this site but I love it already. I have 2 1969 c10's one a short bed the other a long bed, I have been wanting to swap the upper and lower A arms for newer ones because the newer ones have rubber bushings as opposed to the old ones not having it, can I just swap the A arms? if so from what year trucks? or do I need to swap the cross member as well? if so what year trucks?
my short bed also comes with 3.73 posi rear end but it is a 6 lug that I want to convert to a 5 lug, I know there is after marked axles but I was wondering if I could swap them from a newer truck?
kiles_2001 is offline   Reply With Quote
Old 01-26-2011, 04:12 PM   #2
Jeffs70
Jeffs70's Avatar
Re: suspension swap
Welcome to the board, If I am correct I believe its up to 88' that will fit on these trucks.
If it was me and I wanted to convert to newer with 5 lug then It maybe easier to find the whole cross member and slap it in. and a rear axel to match. but I am not to sure. correct me if I am wrong.
Jeffs70 is offline   Reply With Quote
Old 01-26-2011, 05:48 PM   #3
treveiger
treveiger's Avatar
Re: suspension swap
73-87 chevy trucks you can swap the front crossmember completely. Im talking to a guy that might be selling me his front end off his 79 truck. Theres a thread on here about it i printed it out but ill try to find it for you.
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 01-27-2011, 01:34 AM   #4
kiles_2001
Re: suspension swap
that sounds good, I would really appreciate that.
Old 01-27-2011, 01:41 AM   #5
dave2953
Dave's not here, man
dave2953's Avatar
Re: suspension swap
You can swap the arms from a 73-87 truck and 88-91 'burbs. They will work with the existing crossmember. I would imagine you'll want to upgrade to disc brakes as well, correct? If so, you can swap the entire crossmember from one of the aforementioned trucks/'burbs or you can swap the arms and move everything else over. When I swapped to 5 lug, which was just done recently, I changed out the entire rear axle. I obtained one from a '79 half ton truck.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-27-2011, 01:43 PM   #6
treveiger
treveiger's Avatar
Re: suspension swap
Is your truck coil or leaf? dont you have to modify the axle?
Old 01-27-2011, 02:06 PM   #7
dave2953
dave2953's Avatar
Re: suspension swap
My truck is coil. The only thing I had to do was weld new perches onto the new axle since it came from a leaf truck. It was pretty straight forward...
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 01-27-2011, 02:36 PM   #8
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Re: suspension swap
Mine was a leaf spring GMC. I changed to 6" drop coils and added trailing arms (found a great deal at a swap meet for the trailing arms) I also converted front 6 lugs to 5 lugs and used the rear axle and front spindles from a 72 3" drop springs in the front). Easy as Pie, It was like it belonged there. As far as tie rods, those needed to be swapped out to be year specific (71-72) AND also used the year specific (71-72) drag link (tapper is different from the earlier years (67-70)
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 01-27-2011, 03:24 PM   #9
treveiger
treveiger's Avatar
Re: suspension swap
So a later coil rear end will fit on our coil rear ends without any mods?
Old 01-27-2011, 03:39 PM   #10
dave2953
dave2953's Avatar
Re: suspension swap
The later trucks (post '72) were all leaf spring suspension as far as I know. For my application the perches had to be swapped and the way in which the drive shaft attached was also different (straps vs. u-bolts)
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
Old 01-27-2011, 09:10 PM   #11
kiles_2001
Re: suspension swap
my 69 short bed is leaf springs and it came with 3.73 posi and that is the reason Id like to keep the rear end and just swap the axles, it has the ideal ratio and its posi so it is perfect for the set up I want to run. so does anyone know if I could just swap axles from the junk yard? or do I have to go with after market axles???
