Old 03-17-2024, 11:27 AM   #1
Dicky1
New Member
72 C10 Transfer case torque mount
Pulled my TH350/205 Tcase to clean up and do all seals/bearings as required. Reinstalling everything and all went together easily all bolts going back in with fingers …. EXCEPT for the 2 bolts in the torque plate.. the holes in the Tc and the plate are at least 3/4” out line…I realize being a torque plate it may be somewhat out of line so rubbers maybe have a little pressure. I don’t recall a whole lot of pressure on the 2 bolts that go into the case when I removed them.
Why are my pictures always uploaded 1/4 turn out ?
Dicky1 is offline   Reply With Quote
Old 03-17-2024, 11:54 AM   #2
MJN
MJN's Avatar
Re: 72 C10 Transfer case torque mount
Heres a picture from the service manual, it looks like in your pictures you have the t-case mount under the frame mount. Transfer case bracket goes on top, there is a small piece that the mounts kind of sandwich in between and then the frame bracket is on the bottom.
If you need new mounts, I have a brand new set of poly mounts available
https://67-72chevytrucks.com/vboard/...d.php?t=822524
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 03-17-2024, 12:19 PM   #3
Dicky1
New Member
Ok thanks, my rubbers are cracked a little on the outside but not in bad shape otherwise I think… I seen this pic on another thread, mine is like the red circle.. listed as “A”
Old 03-17-2024, 12:20 PM   #4
Dicky1
New Member
Sorry not “A”… the other one
Old 03-17-2024, 01:26 PM   #5
Dicky1
New Member
Well with your help.. I discovered I did Have the plate in wrong position… thanks for your help MJN ! I shouldn’t have quit school in 1975 with only 20 minutes of grade 10 I guess.
