09-11-2013, 03:51 PM | #1 |
OE antenna
Hello,
I'm looking for a picture and a source for the factory original radio antenna that might be found on a 1960 Chevy truck. Also what would be the correct factory radio to install? Thanks -Zetan
1960 Chevy Apache K10 283ci short step 1984 GMC Rally Van 6.2L diesel 1995 Chevy G30 cargo van 6.5L turbo diesel |
09-11-2013, 04:20 PM | #2 |
Check The Champ, Demonstrator
Re: OE antenna
There's a few versions of the original antenna depending on which year it was for, it had a different base below the cowl extension. The parts above are all similar for all years of this series.
The location on the cowl extension varied as well between years. I'll go out on a limb here and say 60-63 was centered going front to back and 64-66 was located more towards the hood. Ebay Find http://www.ebay.com/itm/1960-1961-19...065adc&vxp=mtr Radio was similar to this but with tubes. 1963 was the first year in the trucks for transistorized. 1960 Deluxe/ Medium Duty/Heavy Duty Dash 1961 1963
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 09-11-2013 at 04:32 PM. |
09-11-2013, 04:25 PM | #3 |
Re: OE antenna
Heres the radio pictures
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
09-11-2013, 04:36 PM | #4 |
Re: OE antenna
Get yourself a 1960 Car and Truck Accessories Installation Manual and a 1960 Truck Data Book to start if your interested in original stuff.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
09-11-2013, 04:38 PM | #5 |
Re: OE antenna
Does your K10 have a rear bumper?
09-11-2013, 06:09 PM | #6 |
Re: OE antenna
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
09-11-2013, 09:07 PM | #7 |
Re: OE antenna
Got this oe repop antenna at classic parts, Found the cowl drill location on a previous post and used the template that came with the antenna for the fender extension.
09-13-2013, 04:32 PM | #8 |
Re: OE antenna
Is that side trim on a step side? Was that a dealer option? Do you have any photos of the back where it wraps around the back of the cab?
09-13-2013, 10:50 PM | #9 |
Re: OE antenna
Here ya go, trim is stock but was mostly missing when I got the truck. Maybe because the truck has the deluxe package or someone put a stepside on a fleetsde. I just use the fleetside trim from classic for replacement.
10-11-2014, 12:45 PM | #10 |
Re: OE antenna
does anyone have the 66 chevrolet truck antenna drill template or know the location so I can drill it rite, I found a stock 60 antenna and want to put it in the rite spot thanks
10-11-2014, 01:37 PM | #11 |
Re: OE antenna
Believe you should be looking for a 1960 template vice a 1966. There are 3 OE antennas for our series: '60-'62, '63 and '64-'66 and I know for a fact the hole location is different for '60-'62 as compared to the other years as I just installed my OE '62 antenna into what I thought was a correct hole in the cowl only to find the antenna slanted about 45 degrees off plum. I used the template that came with the antenna and it now looks like it came from the factory -- of course I have an extra hole I have to deal with now! I can scan the template that I have if you want it.
10-11-2014, 01:44 PM | #12 |
Re: OE antenna
oh, didn't know that, the antenna is a 60-62 that I have and is going on my 60, yea scan that would be perfect thanks that's why I didn't want to make a hole off center, I also did that to my nova years ago and was in the same boat thanks
10-11-2014, 03:35 PM | #13 |
Re: OE antenna
Here's a scan of the template that I used. I threw in the ruler so that you can size it up properly to print out. If this scan is too small (had to resize it to meet the forum's picture size policy) I can e-mail the original scan which is a much larger file. Cheers and good luck!
10-11-2014, 05:43 PM | #14 | |
Re: OE antenna
