6l90 compatibility
I’m to the point in my build where I need to obtain a drive train. I’d like to use a 6.0 L and 6L90. Is the 6L90 TCM compatible with a LY6 or do I have to go with the L96
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
Re: 6l90 compatibility
I'm not the expert here by any stretch of the imagination, but I picked up a complete take out from a 2011 Silverado 2500 last year. It is an LY6 with a 6L90 as the factory drivetrain. I have the computer, harness, etc. Since they were a factory combo, I would think that you can find one. I'm not sure what other transmission options backed the LY6, but I'd probably try to find a matched set. That way the computer is already ready to go. I'm sure that some others with more in depth knowledge will chime in soon.
Good luck! Chris |
![]() Join Date: Nov 2018
The only issue that you can’t get around is your crankshaft. You have to use a 58x relcutor, a 24x is not compatible with any of the controllers for a 6 speed
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
Reluctor wheel shouldn’t be an issue when using the factory PCM/ECU/Whatever GM called the computer that year, as long as you’re using a factory engine trans combo... It would be an issue with a standalone aftermarket controller, i.e. if you wanted to carb the engine.
#5 | |
Tbssowners.com is a good place to research this as 07-09 owners have been known to upgrade from the 4L70E that I’m unfortunately stuck with.
#6 | |
#7 | |
This will all just depend on the donor engine harness, but either way it’s doable
Am I correct that the ECM will just have to be reprogrammed so it recognizes the 6L90
#9 | |
![]() Join Date: Jul 2012
If you plan to keep the original transfer case, you will have to install an adapter from your NP205 to 6L90. Worth it IMO to avoid having to go drivers side Tcase drop and change out your front axle.
