Old 10-07-2020, 06:58 PM   #1
truckster
truckster's Avatar
Later Model AC?
Here's my situation: I'm putting my Blazer back together, and I discovered there was a huge hole in the hard line to the evaporator. The new engine is an L31 with serpentine brackets from a 98 Silverado. I had planned to use the condenser and compressor from a 2001 Express 3500 van that's volunteered to be an engine donor for another project. I know it's a long shot, but... has anyone ever used the evaporator from a later model Chevy in a 72 with factory air?
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-08-2020, 08:38 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Later Model AC?
A 1987 evaporator fits well in the original box.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 10-08-2020, 08:59 AM   #3
Thealien
Thealien's Avatar
Re: Later Model AC?
@Katrina/10
Is it necessary to change the evaporator when updating the compressor and condenser? I am doing an LS3 swap in my 1972 Blazer and will be using a sanden S7 compressor and swapping to 134 refrigerant. The reason I ask is I bought an NOS evaporator and would like to use it?
Old 10-08-2020, 09:21 AM   #4
clay68c10
clay68c10's Avatar
Re: Later Model AC?
I’ve also used a square body evap. Fits well, but slightly smaller so you have to make a small spacer inside the case.
I would think the POA elimination would be the way to run the factory evap with a newer compressor on an LS swap. I suppose you could run a POA since it cools great, but I don’t know how that compressor would like a 100% duty cycle.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 10-08-2020, 12:37 PM   #5
truckster
truckster's Avatar
Re: Later Model AC?
Excellent! I just looked it up - $50 vs $300 for a 72 evaporator. Building a spacer should be simple.
Thanks so much!
Old 10-08-2020, 01:02 PM   #6
Katrina/10
Katrina/10's Avatar
Re: Later Model AC?
Thanks so much!
What year did you look up? 73-87 are not all the same.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 10-08-2020, 02:40 PM   #7
truckster
truckster's Avatar
Re: Later Model AC?
I looked up an 87. I also looked up a 98 - it looks close enough to work as well.
So that brings up a question - I have a 98 Silverado and a 2001 Express 3500. Both have the Vortec 5.7 with serpentine (the setup I put in my Blazer) but the 98 has an orifice tube and the 01 has an expansion valve. Which one works better?
