Old 01-25-2020, 08:12 PM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Looking to ID a Holley 6R-8026 4bbl "Carb Shop" carb
Cant seem to nail down exactly what this thing is, I'd like to verify the cfm? It has no choke and mechanical secondary's. I'm building a solid lifter 439ci (.060" over 427) BBC motor with a Clay Smith solid 304 cam, 258 duration @ .050" .615" lift. With a Weiand 7620 single plane intake. I'll post pics directly...Thanks,
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 01-25-2020, 09:00 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Looking to ID a Holley 6R-8026 4bbl "Carb Shop" carb
How about calling them?
https://www.customcarbs.com/
Old 01-25-2020, 09:54 PM   #3
Ironangel
Ironangel's Avatar
Might do that Monday...This carb came with a 69 L34 396 I bought a few years ago.
"Two Seventy Two's"
02 3/4 ton Express
Old 01-25-2020, 10:02 PM   #4
Captainfab
60-66 Nut
You can also measure the diameter of the butterflies and get a good idea by comparing them to the size of specific known CFM carbs. I have a Holley book with all the butterfly sizes.
Old 01-26-2020, 10:30 AM   #5
Ironangel
Ironangel's Avatar
They're 1-11/16" diameter...I found Carb Shop's Facebook page and oddly enough they responded right back indicating that it is a 750 CFM carb. The carb has been on the shelf for years so I'll go through it and check the pump diaframs and jet sizes, etc. I don't think that cam will be making much vacuum so power valve rating will be a concern as well. This is my first Holley carb so everything is a learning experience. Any and all help is greatly appreciated, thanks! 👍🇺🇸
"Two Seventy Two's"
02 3/4 ton Express
Old 01-26-2020, 10:41 PM   #6
Captainfab
60-66 Nut
I looked in my Holley book and it seems that with the double pumpers, the 1-11/16" throttle bore is used from 650cfm thru 800cfm. The flow difference is determined by the venturi diameter. A 750 should have a venturi diameter of 1-3/8".
Old 01-30-2020, 03:26 PM   #7
biketopia
Captain Fab, what holley book do you have that has that info? Looking for a way to ID 850 CFM carbs, as I need one and it seems no one near me know actually what they have and most can't read the #'s
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 01-30-2020, 10:44 PM   #8
Captainfab
60-66 Nut
It is the Holley performance catalog from 1998. I have had Holley catalogs prior to this one that had the same info. There is a section towards the rear of the catalog that has all the carb list #'s and all the specs for each one.
Old 01-31-2020, 07:41 AM   #9
biketopia
interesting, thanks.
