Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > Welcome Area
Old 03-12-2005, 09:40 PM   #1
SGLTRK
Newbi looking for advice.
I'm new to this board and I'm looking for advice on a project that I'm doing research for. My goal is to build a mild custom '67-'72 1/2 or 3/4 ton long bed. The truck will be used as a daily driver and tow vehicle. We will be towing a trailer of approx. 6000lbs across the country so I need reliability and torque for those mountains that are between us (Calif.) and everywhere else. Good fuel economy is important also.
My plan is to build a 383 small block stroker with vortec heads backed by a 700r4 driving a 3.73 or 4.10 rear end. I want to run EFI but I can't decide between TBI, TPI or aftermarket like the Edelbrock multi-point TBI system. The reason that I'm going SBC is because I already have a good 4-bolt 350 core to build on.
Well there you go, kinda long but I'm wide open to any and all advice, criticisms or thoughts.
SGLTRK is offline   Reply With Quote
Old 03-13-2005, 10:47 PM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Welcome to the boards.
I think if i was to build a truck to use as a tow rig,it would at least be a 3/4 ton.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 03-14-2005, 02:23 AM   #3
Josh
He's got mean nasty FANGS!
Josh's Avatar
Welcome to the boards!
I'd go with a 3/4ton for reliability while towing that much that often, the 700r4 im not sure if I would use tho since you cant really tow with it in overdrive anyway.... 4l80 (which is $$$$) or a good 5spd would be my choice...
2004 K2500 Burb
1999 C3500
1985 Cutlass Supreme
1969 C-10
1967 C-10 Panel
josh@67-72chevytrucks.com
Josh is offline   Reply With Quote
Old 03-14-2005, 02:24 AM   #4
Liz
Catchy title goes here..
Liz's Avatar
welcome to the board you might want to post the question over on the 67-72 message board also.. you'll get alot more replies over there
Liz is offline   Reply With Quote
Old 03-20-2005, 01:12 AM   #5
krue
Designated A-hole!
krue's Avatar
Welcome from South Mississippi!
What she said.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
