11-16-2020, 10:54 AM | #1 |
Active Member
6L80 shifter recommendation
I'm installing and L83 with a 6L80 trans and trying to figure out a good shifter to use. Any ideas would be helpful.
11-18-2020, 10:13 PM | #2 |
Re: 6L80 shifter recommendation
my buddy just did a c10 with a lokar ES6L80GM floor mount unit. it is set up to work in 2 modes. has normal operation but move the shifter right and it operates like a paddle shifter with the module installed, just tap shifter up or back to select gear. good luck.
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
11-18-2020, 10:20 PM | #3 |
Carpe manana
Moved thread for more exposure.
11-19-2020, 06:27 PM | #4 |
Active Member
Thanks. I was thinking about that shifter. Would you know what style and length lever he went with?
11-20-2020, 07:33 PM | #5 |
I used a Lokar floor mount shifter in 68 C10 LS/4L60E swap. It uses the rod directly from the shifter to the trans lever. I was concerned it might have some vibrations going down the road but it's dead still. I have Lokar cable type in my 98 Wrangler LS/4L60E swap and it also works very well. I choose the rod type from Lokar because it's a bit cheaper than the cable style.
11-24-2020, 11:29 AM | #6 | |
Active Member
