Power steering, what parts do I need?
Can you guys tell me what all parts I need to convert to power steering on my 68 C10? I知 doing an ls swap and my motor already has the power steering pump. I know I値l need a power steering gear box and pitman arm. What else?
Re: Power steering, what parts do I need?
What year p/s pump are you using? I have just finished putting p/s on my 68 and I used the original 68 p/s box and I had a p/s pump that came with the engine I bought which was a 1983, so I was going to use it. Now I know that the two aren't compatible. one is o ring and one is pressure fitted, so now lines won't mate. But, I did find from one of our members a company called Lee power steering in CA. that can make fittings that make the two use one common p/s line. Let me know how your turns out and how you corrected your problem. Hope this helps.
#3 | |
Anybody else have any info on what else I need? |
![]() Join Date: Dec 1999
I used a pump from a mid 90's GMC. which is the vehicle i pulled all the brackets for the serpentine set up off of. Replaced my leaky, worn box with one from Redhead Steering Boxes. My drag link was shot so that was also changed at that time. You will need an adapter for the pressure port on the pump to take you from the o-ring fitting to the inverted flare needed for the OEM pressure hose. They are available at Jegs, Summit probably has them as well.
Smitty '71 Short Fleetside Spring Valley, Ca. |
