Old 04-26-2003, 11:08 AM   #1
Johns70
Johns70's Avatar
looking for a carb
looking for a used holley 750 or 800 double pumper.
i have a used 750 eldenbrock with low useage for trade.
i have to much cam for the vacum secondarys.
69 chevy short wide box project
70 GMC jimmy project
Johns70 is offline   Reply With Quote
Old 04-26-2003, 01:06 PM   #2
bigjimzlll
bigjimzlll's Avatar
http://www.tpcracing.com/ mine is the red double pumper..he does great work and is very friendly..Yell Ty I sent you
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-27-2003, 09:54 PM   #3
Johns70
Johns70's Avatar
ttt
Old 04-27-2003, 10:34 PM   #4
mikep
Used to have a truck
mikep's Avatar
I've run some pretty radical cams with vacuum secondaries as in up into the 305 advertised duration range with just a little tuning on the secondaries. AFB's arent my favorite carb for other reasons but the secondaries are certainly tuneable for low vacuum cams. I ran one on a 351 cleveland that wouldnt pull more than 10 inches of vacuum and the secondaries on it it ran just fine at WOT . All it takes is a little fine tuning of the secondary counterweight . They used them on 426 hemis for Gods sake and those things had minimal vacuum at at anything over idle . There a couple of good books on Carter tuning that go into detail on the subject. Theyre cheaper than rebuilding a holley and if you like the carter ( weber, edelbrock , carter...whatever ) otherwise you might as well run with it.
No truck :-(
mikep is offline   Reply With Quote
Old 05-09-2003, 01:04 AM   #5
Johns70
Johns70's Avatar
ttt
