Old 08-07-2013, 11:20 AM   #1
terrylgreenjr
K5 C Notch
I'm wanting to install a flip kit on the rear and try to go as low as I came and keep the factory floor. From what I've found so far no one makes a C Notch for the Blazer frame. Has anyone found one?
terrylgreenjr is offline   Reply With Quote
Old 08-07-2013, 02:26 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: K5 C Notch
Not that I know of. Seems most guys cut their own.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-07-2013, 05:59 PM   #3
kevinr1970
Re: K5 C Notch
I have this one book marked:
http://www.airbagit.com/1973-1991-CH...fli-che-04.htm
It is ambiguous in that is also says C10/20, but they also list different kits for C10's?
http://www.airbagit.com/category-s/2242.htm
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-08-2013, 10:38 AM   #4
terrylgreenjr
Re: K5 C Notch
Have you bought the one that list that it fits the blazer?
Old 08-08-2013, 02:43 PM   #5
kevinr1970
Re: K5 C Notch
No, bookmarked for later reference.
2000 Tahoe Limited
Old 08-08-2013, 10:01 PM   #6
bwhit10
bwhit10's Avatar
Re: K5 C Notch
Just bought a c notch from CPP. I have modified the whole thing to fit. Better off to make your own.
bwhit10 is offline   Reply With Quote
Old 08-09-2013, 09:20 AM   #7
Jonboy
Slots go on anything!
Re: K5 C Notch
The biggest problem you will have is with the pumpkin hitting the rear floor. That will hit long before the axle tubes pose a problem.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 08-09-2013, 10:10 AM   #8
terrylgreenjr
Re: K5 C Notch
When I measured last night I had 7in from the pumpkin to the floor but only 4in until axle tube hits the frame I dont think I measured incorrectly but maybe
Old 08-09-2013, 02:30 PM   #9
BIG V
Re: K5 C Notch
is that hitting the frame or the bump stop bracket and bump stop?
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great
1979 Chevy 1/2 ton long bed diesel
1974 Chevy crew cab short bed 3/4 ton 4x4 project
1991 Chevy suburban 2wd
1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo
1961 Chevy pickup 1/2 ton 2wd
1975 gmc crew cab short bed 2wd
BIG V is offline   Reply With Quote
Old 08-09-2013, 02:55 PM   #10
terrylgreenjr
Re: K5 C Notch
The bracket where the bumpstop mounts
Old 08-10-2013, 11:39 PM   #11
bagged74
its just $$$$$
bagged74's Avatar
Re: K5 C Notch
I usually do a 2.5" notch if keeping the stock floor.
bagged74 is offline   Reply With Quote
Old 08-13-2013, 02:45 PM   #12
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: K5 C Notch
here is what I did. Easy to do and at big as you can go if you have a 12 built.
tvblazer78 is offline   Reply With Quote
Old 08-13-2013, 08:05 PM   #13
terrylgreenjr
Re: K5 C Notch
Tvblazer did you box in the frame on the inside? What is the flat plate arch that is welded on the frame for?
Old 08-13-2013, 08:09 PM   #14
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: K5 C Notch
No I did not box it in and the plate is my old bag mounts, i just left them on for now.
