07-02-2009, 10:09 AM | #1 |
cleaning al. intake ?
am trying to clean al. intake that is still on the truck,gets gas and dirt build up,trying to find something to clean it with without going to pressure washer.I want that new look back
09-09-2009, 05:11 PM | #2 |
Project Optimus Prime
Re: cleaning al. intake ?
Me too i have the exact same problem. Anybody out there Help, Help, Help!!!!!
84 SWB work in progress 89 burb 1500 (parts pig) LOL 08 ford focus (I know, I know) Wifes car "I said it b4 and i'll say it agian wiring is my worst enemy":devil: |
09-09-2009, 10:10 PM | #3 |
Parts and more parts
I have gone so far aas to use an aluminum wheel cleaner to clean the pores of the intake out. That was while it was on the motor. HOWEVER, you have to protect ANYTHING that is painted--due to the acid base.
11-15-2009, 11:23 PM | #4 |
try windex
11-16-2009, 03:47 PM | #5 |
Between Trucks...
Beat it to fit, Paint it to match... |
11-16-2009, 04:06 PM | #6 |
Tot Roddin'
Refer to this thread... I'm curious if these products could be used on an intake. Mudder, any experience?
http://www.67-72chevytrucks.com/vboa...d.php?t=369277
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-16-2009, 04:11 PM | #7 |
Tot Roddin'
11-21-2009, 07:50 PM | #8 |
mini truck racer
I guess i'll try the purple power on my intake and post up before and afters . seems like the sand cast is rough , but i'll try it .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-24-2009, 10:05 PM | #9 |
I can tell you from experience that any of the degreasers will work great. BUT!!! Don't use them if you have a shiny carb. It will be dull grey after you're done. Undiluted simple green and a 1" paintbrush with the bristles cut down will work wonders. And it won't dull the carb.
12-25-2009, 09:15 AM | #10 |
mini truck racer
The intake is not installed . I would also like to add some shine to it .
12-25-2009, 10:29 AM | #11 | |
Redefining LowBudget
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
12-27-2009, 07:27 PM | #12 | |
Edelbrock reccomends some brand of Oxy clean stuff. Its on their website somewhere. Not sure if its for and installed intake however. |
12-27-2009, 07:29 PM | #13 |
I've used that a bunch. good for cleaning out the carbon and it will make the outside look better, Won't make it look like new however but better
12-28-2009, 10:24 AM | #14 |
Easiest way will be to remove the carb, you might as well get it fully clean at this point. Use some Mothers aluminum polish (or similar), and painstakingly polish it back out. Q-tips will get you into all the little nooks, but a small felt cone on a dremel will get the job done quicker.
12-28-2009, 11:29 AM | #15 | |
12-29-2009, 10:36 AM | #16 |
I also used a mag wheel cleaner on mine at one time. It worked but wasn't a perfect fix. I would not recomend it to anyone for just the reason stated above. The best and easiest way to clean one is take it off and sand blast it. Once you have it looking good have it clear coated.
You might keep one clean if you never drive your truck or you can go to one of these. |
12-29-2009, 11:23 AM | #17 |
I have done the clear coat thing and you have to be careful of the type of paint that you choose. If you "rattle-can" the paint, the clear coat will turn slightly yellow after time. I have gone to just getting the intakes powder coated with a silver flake and that lasts for a long time.
Frank |
01-11-2010, 11:16 PM | #18 |
The best thing I have done to clean one so far is glass bead blasting. Be sure you are using glass beads instead of sand though, I have heard sand tears it up really bad since its much more abrasive. Many people thought I got a new intake after they saw it. Here is some before and after pics.
01-12-2010, 09:23 AM | #19 |
Tot Roddin'
That turned out nice ag1972, nice work!
01-26-2010, 10:21 PM | #20 |
Plain vinegar and a toothbrush works pretty good!
01-26-2010, 10:24 PM | #21 |
6>8 Plugless........
If you have it off use acid ment to clean aluminum. For instance find a blue beacon truck wash and have them spray it with their aluminum acid. It will make it look like it was just bead blasted. Just don't leave it on too long or it can discolor in spots(Burn the aluminum and areas will be darker than others).
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
01-27-2010, 07:11 PM | #22 |
Grandpa in the rustmobile...
ok gotta ?
eagle one makes an etching mag wheel cleaner.. i use it on my aluminum fourwheeler motor same for intakes? will be trying it when I get my used intake (waiting for gentleman to take it off and swap with my steel one )
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
01-27-2010, 10:59 PM | #23 |
I'm betting it would work on the intake as well.
