05-16-2005, 10:26 PM | #1 |
KEEP ON TRUCKING
2wd coil spring help
72 front hd coils how much do i cut to get 3in drop and do i cut top or bottom.thanks
72 cheyenne 2wd lwb 71 k20 sons bassett va |
05-16-2005, 10:51 PM | #2 |
Turn the spring over an cut 1 coil from the bottom. Dont be tempted to cut two. Cut it directly below where the original end of the spring is. that way it will sit back in the pocket correctly in the lower a-arm. One coil is a shorter spring but also able to support less weight so a smaller compressed height. One coil should be 2 1/2 - 3 inch drop.
72 2wd 307/AT/AC/TILT WHEEL 78 JIMMY HIGH SIERRA |
05-16-2005, 11:15 PM | #3 |
KEEP ON TRUCKING
thanks
