Old 07-11-2002, 09:57 PM   #1
jones
Question fan switch wiring? HELP
please help -
question:
I can't get the fan to blow - but the relay clicks (until the fuse blows 15-20 sec.)
how do I wire my blower fan switch?
or could something else be going on?
background:
when I got the truck the wire plug at the switch was melted - and so was the switch. I've replaced the switch, the resistor & the relay. I couldn't get 12v from the 18g brown wire that was at the switch so I ran a new fused 14g wire to the switch for power. that leaves me with a thick 14g yellow, a thin 18g yellow with red stripe(assuming it would be the orange one in the diagram), and a thinner 18 or 20g light blue wire. I've tried connecting them as per the diagram but the fan won't run - just a clicking relay. I put a jumper from the batt to the fan and it turned fine (although the jumper wire got very hot)
what am I missing (besides the skill to find this problem)?
one wiring diagram I got says there are 5 wires?
the diagram in my haynes manual says there are 4?
please see attached pic and comment. thanks in advance
J
jones is offline   Reply With Quote
Old 07-11-2002, 10:15 PM   #2
Huck
Huck's Avatar
Had similar problem which was solved when GMC Paul told me to re-do the grounds --both at the heater relay and at the fan motor. I suspect that if the jumper wire to the heater is getting hot----you have a grounding problem. Is this an A/C truck?
Huck is offline   Reply With Quote
Old 07-11-2002, 10:15 PM   #3
RipMeyer
RipMeyer's Avatar
To start I would try to run the same gage wire all the way.
Lemmie check my factory manual.
RipMeyer is offline   Reply With Quote
Old 07-11-2002, 10:45 PM   #4
RipMeyer
RipMeyer's Avatar
Here is what I found under my dash.
#1 Yellow
#2 Orange
#3 Brown
#4 Lt Blue
Old 07-11-2002, 10:58 PM   #5
RipMeyer
RipMeyer's Avatar
Just confirmed from the factory manual. What I have is correct.
Old 07-11-2002, 11:07 PM   #6
RipMeyer
RipMeyer's Avatar
Here is a Pic
Old 07-11-2002, 11:34 PM   #7
jones
thanks all!
Huck
it's an AC truck-
grounds are all ok (bypassed them with jumpers)
RipMeyer
thanks for the pic
I just hooked it up according to what yours is
#1 Yellow
#2 Orange
#3 Brown
#4 Lt Blue
see pic
and the fan runs in the 2nd click from the top(position 3?), but nothing at the 1st & 3rd click from the top(position 2 & 4)
the relay clicks loudly and the 4a fuse I had inline blew (replaced with 15a)
ideas???
Old 07-11-2002, 11:35 PM   #8
jones
this is what I have for wires...
the blue one is shorter because the end was burnt
Old 07-12-2002, 12:15 AM   #9
RipMeyer
RipMeyer's Avatar
After looking at the diagrams the only thing I could suggest is the Resistor, Relay and the Switch. Seeing as you already replaced those, maybe you fried one of them when it was hooked up wrong. Switch is more than likely ok but the resistor and the relay may have been damaged.
Old 07-12-2002, 11:01 AM   #10
jones
Talking
wierd -
I re-connected the wires to the switch, re-re-checked the grounds and this time it works.
YAHOOOO
no I just wait for the duracool to show up so I can charge this baby and go. today's high forcast at 110. It's not suppesed to get this hot in Idaho.
anyway, thanks for the input RipMeyer & Huck - it helped to get the wires plugged in to the right spot.
Old 07-12-2002, 06:58 PM   #11
RipMeyer
RipMeyer's Avatar
GOOD JOB!!!
Thats why we all hang out here.
Old 07-12-2002, 09:05 PM   #12
jones
did I say the forecast was for 110???
69 C15
86 K20
