Old 10-23-2005, 03:26 PM   #1
gmc71
gmc71's Avatar
NP 205 shifting HARD.
Today is the first time I have had any difficulty shifting form 2wd into 4 hi or 4 low. The only way i could get it back to 2wd from either 4 hi or low was to rock the truck forwards and reverse a bit, I could do it but felt lucky that it went into or out of 4wd. Whats going on here? Any suggestions.
72 Chevy 4x4 350
55 Chevy Bel Air 350/350
53 Matchless G80s (motorcycle)
06 Trailblazer SS 400hp LS2
gmc71 is offline   Reply With Quote
Old 10-24-2005, 06:24 AM   #2
al's71gmc
4 eyed fever
al's71gmc's Avatar
Re: NP 205 shifting HARD.
Do you have a lot of play in the shifter? Maybe needs new linkage bolts/pins? Mine in the 71 was pretty hard to shift right before the bolt in the linkage snapped off. I replaced it and another one and it's much better now. The one that broke was the one that screws into the back of the transmission, and the only way I could get it out without dropping the whole unit was to take out the hump and weld a nut onto the broken end. It worked like a charm, but would have been a lot easier if I had checked and replaced linkage before it broke.
Is there a chance the linkage got bent?
Have you checked the fluid level?
Good luck, Al
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 10-24-2005, 07:59 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
I have a 205 with a 4 speed and a 205 with a automatic. And I always had to rock mine. And the linkage is in good shape.I lock the hubs in first, then shift. Sometimes with the auto i have to shut the motor off.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 10-24-2005, 04:08 PM   #4
gmc71
gmc71's Avatar
Short of sounding like a fool, how do you check the fluid level? I see a drain plug, and an inspection cover. Whats the right level, I assume I should change the fluid? How much, any recomendations on fluid brand?
72 Chevy 4x4 350
Old 10-24-2005, 04:57 PM   #5
b454rat
There are two drain plugs on the 205. One is near the bottom, and the other is diagonal from that, just about underneath the rear shaft output. After you drain it, put the lower plug back in and fill it till fluid comes out of the upper plug.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 6” lift
1999 GMC Yukon 350/4L60 4" SAS
Old 10-24-2005, 08:42 PM   #6
gmc71
gmc71's Avatar
thanks, do you think that will help, or maybe fix the problem?
72 Chevy 4x4 350
Old 10-25-2005, 07:50 AM   #7
OLDCHEV4X4
OLDCHEV4X4's Avatar
mabey..if it was low on oil. I use 80w-90 gear lube. It never hurts to change the oil. Try and change it when its hot.
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
