12-15-2005, 10:36 PM | #1 |
U-joint for steering shaft coupling?69 K20
My body lift is pretty tall & im a little concerned about the stress on the coupling. Does anyone make a u-joint to replace it? I'm open to any suggestions.
12-16-2005, 12:49 AM | #2 |
Re: U-joint for steering shaft coupling?69 K20
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
12-16-2005, 01:50 AM | #4 |
You guys wouldnt happen to have a part # would you?
12-16-2005, 09:03 AM | #5 |
another choice that has them --expensive little dudes
http://www.speedwaymotors.com/error/....com/index.asp |
12-16-2005, 11:39 AM | #6 |
I'm using one from Borgeson - here is a link with info for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=101550
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-16-2005, 02:41 PM | #7 |
Mine came out a Chrysler minivan and it is welded in. I had two at one time but was having trouble with it binding. We took one of them out and have had no problems since.
12-17-2005, 05:05 PM | #8 |
I used one from a Chevy Astro minivan on my S-10. I have another one I'm gonna use for my 72 someday.
You have to lengthen the shaft but it has real u-joints and the splines should line up. I think Chevy had two different spline sizes though? Pic of iton the S10;
72 C20 4X4 454 4 speed 89 Trans Am (was) 305 TPI 700r4 93 C1500 2wd Extended cab 350 700r4 98 Sonoma (TPI outa the Trans Am) 03 Yamaha 660 Raptor 03/04 660 Raptor 07 700 Raptor 85 Honda Odyssey |
12-29-2005, 05:15 PM | #9 |
PROJECT 7DEUCE
Little toyota pick-ups have then also with u-joints on both sides..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-11-2006, 05:45 PM | #10 |
If you go Borgeson, FlamingRiver, etc., get a vibration reducer joint so the road-induced vibrations don't reach the steering wheel. The rag joint is imprecise, but it does a good job absorbing vibrations– unlike straight yokes/joints. And be sure to install any set screws with locktite so you don't lose attachment while on the road.
The Borgeson site should have a section for measuring your set up for the length you need. Know your male shaft diameters & spline counts and be sure you are thru with body lift changes or cab support changes so the length is right till the next major change.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup. |
02-12-2006, 12:55 AM | #11 |
the "small" Jeep Cherokees (XJ) have ujoint steering shafts too.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
