07-23-2002, 11:31 PM | #1 |
original type tires for a '68
Hey guys can you help me out with something? A good buddy of mine has a '68 long wheel base stepside that he put a built '68 chevelle 396 in it. He is wanting to put the original size tire back on it. I work as a tech in a tire store so i can get him a good deal but i don't know what type of tires came on it.
he says that his dad ordered the truck new with tires that would normally go on a 3/4 ton even though it is a half ton. he calls the tires 6 ply 715's. I am not familiar with this sizing method i only know the metric size method. what he wants is a tire that is the same height and similar width to the 3/4 ton type tires that came on it, it does matter if they are actually original type 6 plies, they can be radials. can some of you guys point me in the right direction? thanks very much, ryan c.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
07-23-2002, 11:37 PM | #2 |
i have the original set of rims off my 69 gmc, and i would assume that the tires are about the same size, but they are measured in metric, so they would probably be the same, but my pickup is a half ton? if you think the numbers would help just say, tomorrow i will go unbury them and look for you if you need, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
07-24-2002, 12:05 AM | #3 |
Just saying hey to neighbor truck fan.
That 68 sounds like something I would like to see. I am not sure about the stock tire size. wallace wade sells speciality tires in Big D. http://www.wholesale-tires-usa.com/
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
07-24-2002, 11:36 AM | #4 |
benrs86 - that would be great if you don't mind, it might help point me in the right direction.
hutch - it is a pretty cool truck, his dad bought it new with a 307 and then passed a few years latter and my buddy has had the truck ever since. in the early 90's he built up that 396 and put it in along with a muncie 4 speed. it is a very unique looking truck b/c of the lwb step side. it is no show piece, its in primer and rust, but still very cool. any one else know about those tires?
07-24-2002, 03:54 PM | #5 |
I replaced the original 16.5 inch wheels and tires on my 68 C20 with 16 inch wheels and 265-75-16 radial tires. This are wider than the original tires, but about the same height and diameter. They look good and keep the speedo accurate.
1968 Chevy C20 327 4spd Custom 66k |
07-24-2002, 05:46 PM | #6 |
i guess these tires arent right. they look small and nerdy, like something that would come on a 69 gmc. they are p195/75s i think that would be about the right size, but they didnt come with passanger car tires. maybe lt195/75s are right. this is on a 15 inch rim though. good luck, hope this helps, Ben
07-24-2002, 07:12 PM | #7 |
OzarkHillbilly in Atlanta
tire info
Couple of ideas here. Check out this site to see if it helps.....
http://www.tirerack.com/tires/tirete...conversion.htm the next idea is I have a 66-69 "Chevrolet Pick-Up Trucks" Vehicle Load Capacity Guide....It has charts of tire, wheel and spring combinations and the GVW of those combinations...If you can get the model # and any spring options on the truck I'll try to figure out what size tires it had. I havn't quite figured out this book but if ya post that info maybe i can figure it out.
72 custom/10 LWB 68 Longhorn C20 Custom Camper (sold) |
