Old 10-14-2011, 12:16 AM   #1
1968robinsegg
Question c20 suspension recap?
hello everybody another newbie here, found this site the other day and have been reading ever since! awesome site-so much information its unbelieveable and everyone seems so happy to help! its very appreciated!!
my question is this- i just got a 1968 c20 with rear leafs, 8 lug, manual steering and brakes.
from what i gather and excuse me if this incorrect- the front suspension from a 73-87 1/2 ton chev or gmc truck/van will bolt in place to get 5 lug bolt pattern,front disc power brakes? also i can use the booster and master and the p/s parts?
the rear diff will be wider by about a inch and a half and will need new perches welded on with a 2 or 3 degree down pinion angle?
last ?? i was thinking of using the 5" lowering leafs from early classics, has anyone used these? good or bad??
thanks for the help!!!
1968robinsegg is offline   Reply With Quote
Old 10-14-2011, 01:00 AM   #2
SCOTI
SCOTI's Avatar
Re: c20 suspension recap?
Correct.
1/2 tons? Yes. 8-lug 3/4 tons might be the same width.
Just about everything from their catalog is a quality part. But for 5-6" of drop, flipping the rear to the top of some stock 1/2 ton springs might work just as well.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-14-2011, 01:11 AM   #3
1968robinsegg
thanks for the reply good point about the axle flip i guess that slipped my mind. my hope is to get a donor truck and get all my parts in one bunch, hopefully will be a winter spent in my garage!!
if i did the axle flip--if i weld the perches parallel to the original ones i'm thinking my i wont have enough pinion angle?(probably be around 0 deg.) or would it stay the same?
Old 10-14-2011, 01:26 AM   #4
SCOTI
SCOTI's Avatar
If you have to weld the perches, might as well set the pinion as close to ideal as possible. Shims can adjust more after that if needed.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-14-2011, 02:27 AM   #5
1968robinsegg
sorry everybody i see now going farther back this has been talked to DEATH!!!
thanks for the help and patience though!!
Old 10-14-2011, 03:55 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome to the board!
There are quite a few subjects that get "talked to death".
But that's why we are here.
Keep us posted on your project,... and remember,... we like pictures!
Ha.
Keith
Convert to disc brakes.
