Old 06-03-2007, 01:55 PM   #1
BarryB
BarryB's Avatar
Lay rockers??
Is it possible to lay rockers, without going through all the work of z'ing the frame??I am wanting to put bags on so my truck lays as low as possible when it is parked. And have a decent stance while driving it down the road. I am considering a 4/6 drop anyways. What are the parts I will have to have in order to achieve this?? Drop spindles? C notch? Any warnings would be greatly appreciated.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 06-03-2007, 02:12 PM   #2
71chevylowrider
71chevylowrider's Avatar
Re: Lay rockers??
I bet this guy would know
http://67-72chevytrucks.com/vboard/s...light=dragging
71chevylowrider is offline   Reply With Quote
Old 06-03-2007, 04:50 PM   #3
BarryB
BarryB's Avatar
Re: Lay rockers??
Yeah I bet he would i was reading that same thread yesterday. Thanks
Two rules in life.
Old 06-03-2007, 07:55 PM   #4
dave2953
Dave's not here, man
dave2953's Avatar
Re: Lay rockers??
If you're wanting a 4/6 drop you don't necessarily need bags. You could use a drop spindle (if you convert to disc) and rear drop springs. Some of the board vendors sell complete disc swap kits with a drop of your choice. I think you need quite a bit of modification of our truck to lay rocker, but don't quote me on that.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 06-03-2007, 08:12 PM   #5
Robznob11
Robznob11's Avatar
Re: Lay rockers??
i have a 5.5/6 with a 3 in body drop and bumper is 4" off ground rocker is 6 front 7 back rear roll is about 9 in. that said mine sits about where a aired out bagged truck sets but mine is there all the time. now if i just swapped to baggs my self and aired them out id be real close to laying rockers. the body drop is fairly easy on these trucks expesially if you have a wood floor bed. and its cheap too if you can get free metal from a local scrap yard. i lost about 1.5 in of my cab floor hight in the center section that spans the frame, another words your fram rails will extend about 1.5 in through the floor wich needs cut and raised...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-03-2007, 10:03 PM   #6
BarryB
BarryB's Avatar
Re: Lay rockers??
Well do you guys have any pics with your trucks aired out with a fairlly stock set up??
Two rules in life.
Old 06-04-2007, 12:22 AM   #7
crzngmychvy
"1972 C5"
crzngmychvy's Avatar
Re: Lay rockers??
Here is mine. No notch, bags, drop spindles.
- 72 2wd Blazer ...sold...
2wd Blazer Page
crzngmychvy is offline   Reply With Quote
Old 06-04-2007, 12:25 AM   #8
bagged7185
bagged7185's Avatar
Re: Lay rockers??
yeah its possible get ahold of nathan over at porterbuilt.
bagged7185 is offline   Reply With Quote
Old 06-04-2007, 06:25 PM   #9
BarryB
BarryB's Avatar
Re: Lay rockers??
Looks like, I will have to put in a notch. I was planning on it anyways.Now did the 2wd Blazers have the coil springs in the back??
Two rules in life.
Old 06-04-2007, 06:43 PM   #10
Robznob11
Robznob11's Avatar
Re: Lay rockers??
check out how they do it on IF customs web sight
LED TAILS
Old 06-04-2007, 06:46 PM   #11
Robznob11
Robznob11's Avatar
Re: Lay rockers??
mine looks like the white one above only it rides there all the time... looks cool but speed bumps present an issue. thank god west texas is flat as a board....lol im 5 ft 9 in and the top of my cab is chin hi
LED TAILS
Old 06-04-2007, 07:03 PM   #12
Rokcrln
Rokcrln's Avatar
Re: Lay rockers??
Here is "Slow Build" (doa search for my thread) that is bagged, 2" body droped, 2" Z'd as well. It is close to laying rockers but if I did it again I would go with a dropmember (PorterBuilt street rods) and a back half! Also I only Z'd the back!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
