05-04-2022, 03:00 PM | #1 |
Upper trim & lower trim holes
Hey guys I haven’t chimed in in a minute hope everyone’s off to a good start in 2022 with their lives and projects…
I’m doing a two tone Blazer and wanted to see if anyone could help with the hole spacing location on upper and lower moldings with any diagrams/measurements. they could text to me Thank you in advance… Ray… 614-949-6906 God Bless 🇺🇸.. |
05-05-2022, 03:35 AM | #2 |
Re: Upper trim & lower trim holes
I don't think blazers ever came with upper trim, but it has been done. I am in the process of adding upper and lower trim to a long bed truck now. I had all the trim before i drilled holes so i could check how it was going to lay out. i did have some cabs and doors with trim holes to measure from. The upper trim holes on mine are 13 1/2 inches up from body line. and the lower trim you would set the top of the trim pieces just about a 1/4 below the body line.
1972 C10 SWB 383 M22 1972 K20 454 1970 K5 1985 M1008 1986 M1008 2020 2500HD Duramax |
05-05-2022, 03:41 AM | #3 |
Trying to add a pic, not sure this will work
05-05-2022, 07:21 AM | #4 |
Carpe manana
Ray check out this thread http://67-72chevytrucks.com/vboard/s...d.php?t=221881. Some two-tone Blazers have sold on Bring A Trailer that can serve as references for upper trim placement along the bedsides. A frequent mistake I see with upper bed trim added to pickups is a parallel position relative to the bed rail, which aligns the rear end of the trim too far above the reverse lamp/rear tail lamp trim.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland Last edited by DeadheadNM; 05-05-2022 at 07:22 AM. Reason: Passive voice |
05-05-2022, 08:01 AM | #5 |
Got it …. I knew I seeen them before
I even searched it but couldn’t find them . Thanks guys for chiming in…. |
