Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-08-2008, 01:13 PM   #1
bigjimzlll
bigjimzlll's Avatar
My combo
I had an old hay hauler(67 C10 LWB fleetside) That had a 283 and a granny 4 speed.
I swaped to a mild 355 with a th350. Best ET was 14.2 at 90 mph. I then coninued to upgrade parts to go faster...and as things started to break
Fast forward to today
I stripped the bed down to just the sides and a tail gate skin. I made a tube frame for the back half. Installed a S&W ladder bar kit. I'm using a 9" rear with a nodular center section with 4.86 gears a a spool.
I made an aluminum bed cover that has a removable rear section to get to the fuel cell and twin Optima batteries.
The rear shocks are Koni double adjustable with 170lb springs.
I had a custom 2 piece drive shaft made.
I made a 10 point roll cage and had cerified by the NHRA to go as fast as 8.50 ET.
The front half is an S&W A arm square tube kit with QA1 coil overs with 350lb springs.
The truck weighs 3175lbs.
I run a custom built th400 with a Hipster brake and all the good internals. The converter is a spec-rite 9' spragless that stalls to 6000 rpm. I also use an 8' ATI that goes to 6700rpm. The Ati is a little faster but the spec-rite is more consistant.
I use a air shifter an electric base plate throttle stop. I have a dedenbear lightning plus delay box that controls the air shiffter and T stop.
The engine is a dart block 540ci with AFR 345 heads. RFD ported super vic intake with a BG Holley 1150 dominator. It has 13-1 CR and made around 850HP at 7300 rpm on the dyno. Mike Lewis from Lewis racing engines built and dyno'd the engine.
I'm still tuning the suspension and it has run a best of 9.66 at 140mph at 2200' DA.
I'm licensed to run SST,SG and ET.
I plan on running the SST(super street) tour this year. SST is a 10.90 index.
video Click here to watch MOV00769-86
pics
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-08-2008, 04:14 PM   #2
Super73
Super73's Avatar
Re: My combo
Fast truck for sure. At 3175, you are a bit lighter than I. Any idea if the change in front suspension shaved weight for you? If so, how much?
From some of the shots it looks like you no longer have a dash, run a solo seat ect.. What other things have you done to shave weight. I'm trying to find areas to get mine on a diet..
You have a glass hood? Fenders?
Shaun
Super73 is offline   Reply With Quote
Old 01-08-2008, 04:27 PM   #3
bigjimzlll
bigjimzlll's Avatar
Re: My combo
Glass hood. I bet I lost 200lbs off of the nose with front half. I have an aluminum dash now.
One of the biggest was the bed. I'm just using the outer bedsides and a tailgate skin. The whole bed weighs about 80lbs now.
There wasn't a lot of weight saved by the dashboard...I just need access for the cage.
It could of been lighter if I would of used chrome moly instead of the .120 DOM tubing. We over built everything(being the first time we built one)
Anderson,CA
Old 01-09-2008, 06:25 PM   #4
bighead
Re: My combo
Cool truck bigjim. Do you have anything for a floor in the bed or just tubs and a cover at the top? big
bighead is offline   Reply With Quote
Old 01-09-2008, 06:26 PM   #5
bigjimzlll
bigjimzlll's Avatar
Re: My combo
just tubs and the cover..the only thing I haul is azz.....lol
Anderson,CA
Old 01-09-2008, 07:45 PM   #6
djracer
djracer's Avatar
Re: My combo
I'm glad we finally got our own section!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-10-2008, 07:16 AM   #7
57sailplane
57sailplane's Avatar
Re: My combo
that thing is light bigjimzIII,
do you have any pictures of the tube front end.
i hope mine is that light but i dont know since i am runing full frame.
yes, very glad we have a knew drag thread.
this is my new destop short cut to this site.
57sailplane is offline   Reply With Quote
Old 01-10-2008, 02:06 PM   #8
bigjimzlll
bigjimzlll's Avatar
Re: My combo
Anderson,CA
Old 01-10-2008, 03:06 PM   #9
djracer
djracer's Avatar
Re: My combo
Jim is that 3175 with or without you? Mine is 3150 with me in it!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-10-2008, 03:28 PM   #10
bigjimzlll
bigjimzlll's Avatar
Re: My combo
Kevin that's 3175 with out my 270lb in it.
BTW..I just bought an alcohol dominator going to the dark side
Anderson,CA
Old 01-10-2008, 03:31 PM   #11
djracer
djracer's Avatar
Re: My combo
In my old camaro I ran a flying toilet on alcohol. I loved it.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-10-2008, 03:46 PM   #12
Evans
Evans's Avatar
Re: My combo
Bigjimz , what radaitor are you running ??
Evans is offline   Reply With Quote
Old 01-10-2008, 03:49 PM   #13
bigjimzlll
bigjimzlll's Avatar
Re: My combo
A cheap Northern 31x19. I think they run around 150.00. I use a Hughs shroud and a elcheapo electric fan. Keeps it cool in "hell"..our summers get to 117 degrees for weeks on end.
Anderson,CA
Old 01-10-2008, 03:56 PM   #14
djracer
djracer's Avatar
Re: My combo
These guys are the friggin bomb if anyone want a custom Radiator. I'm like Jim I think I could drive mine to the beach 3 hours away!
(With 1000 in fuel and an alternator!)
http://www.fsrproducts.com/
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-10-2008, 04:20 PM   #15
Evans
Evans's Avatar
Re: My combo
Thanks !! I need to upgrade my stock one and wanted to keep the factory mounts ... I did the elctric fan in the factory shroud mod ....
