Still Just Havin Some Fun!
![]() Join Date: Jun 2007
Pulling Disc Brakes from a 72 to install on 67
What parts do I need to take besides the spindels and rotors?
a green one with some stuff done to it.... |
Re: Pulling Disc Brakes from a 72 to install on 67
I would take the whole front crossmember. The drag link and everything are different, but the 67 link can be made to work with the right tie rod ends if that's not an option.
Have you considered doing a 73+ front crossmember swap? If I had it to do over again, I might have just gone up to that setup. The ball joints tie rod ends, etc are much less expensive.
![]() Join Date: Mar 2005
you will need all the brake lines ( metal & rubber ) from the spindles to the master cylinder. the lines route differently on the disc brake trucks. get all the steering linkage, this will make the swap easier. you will have to change your lower ball joints( buy new ). when i done mine i swapped spindles & upper a-frames,steering linkage,all brake lines with brackets from a '72
That helps a bunch!
Life, Be In It.....
![]() Join Date: Oct 2003
I agree.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
![]() Join Date: Dec 2004
i second the whole crossmember thing,you will save a ton in replacement parts
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
I am using 72 disc for my 65 so can I use my lowers if I buy new ball joint and if so what do I buy?
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
