05-23-2008, 01:27 AM | #1 |
quest. regarding collapsing steering column
I have read Putter's post about doing this
and have seen what one member did about re-locating the switch components (located approx 1.5- 2" back from the firewall), but is it possible to slide that switch assembly back up and re-rivet it back in place? PS: -- i haven't started pulling everyting apart yet because i've been using the thing as occasional transpo. --- the answer may be obvious when i drop the column, i just hadn't seen it addressed on here
Are you retired too? Nonsense! I'm in my prime Last edited by streetstar; 05-23-2008 at 01:27 AM. |
05-23-2008, 03:34 AM | #2 |
its all about the +6 inches
Re: quest. regarding collapsing steering column
it shouldn't be rivited at all. There is an adjustment in that switch... you'll see it when you drop it down.
