04-21-2009, 01:13 AM | #1 |
Hydroboost?
Hey Guys
I'm going to put a hydroboost in my truck. Do any of you know if the flange that bolts to the master cylinder is the same on a unit from 1995 astro van and a 2003 chevy truck? The wrecking yard will sell me either one for tyhe same price and if the flange is the same I prefer the newer one. Kim |
04-21-2009, 02:32 AM | #2 | |
Re: Hydroboost?
this is unless you get a kit with an adapter. but the astro piece is very nice and will work fine. |
04-21-2009, 07:51 PM | #3 |
Re: Hydroboost?
The flange is the same . You will need a master cylinder that uses a short rod. I just install hydroboost on my '67 chevelle and I used a '78 corvette master cylinder.
FYI; I bought my hydroboost from pull-a-part for $15.00 Last edited by y72ss; 04-21-2009 at 07:53 PM. |
04-22-2009, 12:05 AM | #4 | |
Re: Hydroboost?
I think I will just get the master cylinder that's on the hydroboost unit and save myself some trouble. Out here they want $100.00 for the hydroboost from the wrecking yard. I wish I could find one for $15.00. Kim |
04-22-2009, 01:15 AM | #5 | |
Tripple Five Fanatic
Re: Hydroboost?
Tri5 |
04-22-2009, 09:03 AM | #6 |
Re: Hydroboost?
Thanks Tri5 I'll give them a try.
Kim |
04-22-2009, 01:18 PM | #7 |
Hollister Road Co.
Re: Hydroboost?
This may give you some guidence on parts and part numbers. If your not using a Ford rack ignore the bypass valve.
http://www.thehollisterroadcompany.com/hydroboost.html |
04-22-2009, 03:18 PM | #8 | |
Re: Hydroboost?
Kim |
05-04-2009, 01:50 PM | #9 |
Re: Hydroboost?
Kim57,
What's the outcome on your research? I'm keeping an eye on what you are doing because I already have a setup that I'll try to install sometime in the future. Tri5 |
05-04-2009, 03:58 PM | #10 | |
Re: Hydroboost?
I'm building a bracket to mount it behind the cab on the frame to make it easier to service the reservoir. Kim |
05-04-2009, 05:01 PM | #11 |
Re: Hydroboost?
That's clean, what are you going to do about the rod to the brake pedal? going to replace it for a longer one?
what's the deminsion on that bracket you made? Tri5 |
05-04-2009, 11:55 PM | #12 | |
Re: Hydroboost?
The bracket is 3/16" thick. It's 5-3/4 tall. The end the booster bolts to is 5-1/4" and the long side is 8". The support bars are 3/4" Kim |
