Old 11-27-2023, 05:44 PM   #1
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Caddy 500 in a Squarebody
I Recently bought a C30 Crew cab with no Engine or trans
I have a mid 70s 500 Caddy engine sitting for a another project
As Smallblock chevys and Big blocks are getting really expensive over here in Europe and want to use this caddy engine
I have made a rear sump oil pan and pickup tube
From research i found out that the stock Chevy engine mounting bracket can be used with caddy mounts if i flip them from side to side.
But i read that it might have some firewall clearence to do
Anyone have any pictures of this swap in progres?
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 11-27-2023, 08:06 PM   #2
kennyw
N9PHW
kennyw's Avatar
Re: Caddy 500 in a Squarebody
It has been done many times before and I have a parts truck with a 472/500 Caddy motor in it. No reason to clearance the firewall.
"I got it one piece at a time and it didn't cost me a dime..."
kennyw is offline   Reply With Quote
Old 11-27-2023, 08:10 PM   #3
kennyw
N9PHW
kennyw's Avatar
Here are a couple pics.
Old 11-29-2023, 08:37 AM   #4
cerial
cerial's Avatar
If your using the TH400 then the only difference is the tailshaft. Easy enough to swap out in most cases. Worst case you shorten a driveshaft.
If your planning on keeping the sm465 that is where things get a bit tricky. Cadco has a flywheel and the thing is a Heavy sob. It is also quite thick.
https://cad500parts.com/product-category/driveline/
Call them to make sure your getting the right stuff for the application
I had a Lakewood bell(opened up to the sm465's larger bore), 1/8" block protectior, adapter plate, the thick flywheel and from there it was a basic BBC 454 clutch. But I only had like 1/16" between the block protectior and the flywheel. A mini starter was needed also because the Cad starter nose would not fit inside the lakewood.
Plan on dropping $500-600 in cad co parts plus another $200 for a BBC clutch.Watch the tooth count on the ring gear or your going to need to play with the starter also.
I have had 3 500's and 2 472's in squares. I had my last 472(68High C) sitting in the shop and finally got rid of it this summer. Those Cad engines blocks love to drink and in a square plan on 6 and if your lucky 8mpg. They are fun in a mudtruck where you want that torque. But they do have issues with oiling, valves and everything is more expensive then a BBC. An LS is a much easier option especially if you want to keep the sm465. Bolt in deal with the parts to bolt the engine up to that sm465 about 1/2 the price of the cad stuff.
1991 Metro commuter
1991 s10 future project truck
1987 V10 backup daily/junk truck
1985 K20 Winter beater
1991 R30(squarebody) c/c flatbed towrig
1994 s10 80"wb custom build
cerial is offline   Reply With Quote
Old 11-30-2023, 05:33 PM   #5
GmtGmt
GmtGmt's Avatar
I have a chevy TH400 with an adapter thats allready fitted to the engine
Thomas
Old 12-01-2023, 02:31 PM   #6
mr48chev
mr48chev's Avatar
There may be more room on a square body but on my 71 I had left head to firewall clearance issues. My 77 one ton seems to have more room though and it has a 454 in it. I wish it had the 500 and automatic in it.
This is from when I was fitting the motor mounts up and the oil filter clearance is tight and the fuel pump is on the drivers side requiring a longer hose but that isn't an issue except remembering to pick up the hose on a parts run. Exhaust clearace is tight on the right side, My son and I heated and bent a section of the frame rail down by the exhaust manifold for clearance when we were fitting the engine, heat, and a bit of massaging with a 2-1/2 lb hammer and it clears and the frame isn't comprimised. You can see it in this photo but the photo wasn't of that.
Good luck, that has the makings of a nice truck to wheel down the road with.
My ongoing truck projects:
Old 12-03-2023, 05:30 PM   #7
GmtGmt
GmtGmt's Avatar
What formed Radiator hoses do you use that will fit or has to be modified to fit
stock Caddy hoses or the truck hoses?
Thomas
