Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 06-01-2009, 04:09 PM   #1
oomag12
Just Curious
My son bought his first vehicle, a 2001 S-10 blazer 4wd, auto, 196,000. He gave 1000.00 from a dealer selling it as a "handyman special", in other words as is. She is loaded fully electric, moon roof , actually clean as a pin. Turns out the tranny needed replaced and I located one at the salvage yard and got a local mechanic to install it for him. He charged 757.00 to install including a BG fluid flush,and a new filter. The boy wheeled her around a day and had a pretty significant leak at the transfer case tail shaft. Obvious outer seal leak. Wasn't leaking prior to the tranny swap...thing is he charged 70.00 more...whats the average in your folks area for a tranny swap with a transfer case and how would you think on outer seals? Included in the price for install??? I appreciate your input.
oomag12 is offline   Reply With Quote
Old 06-01-2009, 04:35 PM   #2
corn
Re: Just Curious
Why would he replace transfer case seals? Unless of course, you asked him to...
corn is offline   Reply With Quote
Old 06-01-2009, 05:42 PM   #3
oomag12
Re: Just Curious
Seeing that the transfer case has to be removed to install the tranny, and re-installed,would'nt you notice a significant leak at the tailshaft after the swap?? Wasn't leaking prior, I ran the old gal about ten miles pretty hard, no leaks.
Old 06-01-2009, 08:06 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: Just Curious
Seals need to stay lubed. If it sits for a while they contract or crack. Once you start to drive it, the seal heats back up and seals properly. The rear seal should not be hard to replace. I think you got a good price. A tranny on a 4X4 install costs more than just an auto.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gitter her right gm, hummer...come on, olds, pontiac
