Old 08-06-2009, 01:40 PM   #1
BGRAFX
Best way to Lower a suburban?
Hey guys, I'm looking for best opinions and pictures on lowered (non airbagged slammed) suburbans. would like to go lower then the 2/2 that LMC offers. I have a 91 2wd 1500.
thanks in advance for your posts
BGRAFX is offline   Reply With Quote
Old 08-06-2009, 05:05 PM   #2
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Best way to Lower a suburban?
Here is one place to look DJM. 2" shackles and 2" springs.
http://www.djmsuspension.com/product...c%20table.html
Can anyone help out on what you did on your?
tvblazer78 is offline   Reply With Quote
Old 08-06-2009, 05:28 PM   #3
BGRAFX
I know where to buy lowering components, I'm just looking for some advice maybe from the blazer guys. Why is a 2/2 drop my only option. Can I do a 3/5. Withought any issues?
Old 08-06-2009, 07:13 PM   #4
flamingbig10
6.0 powered square
flamingbig10's Avatar
here's a few
[/QUOTE]
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-06-2009, 07:17 PM   #5
flamingbig10
6.0 powered square
Aaron
Old 08-06-2009, 08:17 PM   #6
tvblazer78
Low & Fast!
tvblazer78's Avatar
If you did a flip kit you would get about 6" out of that. But you can do the 2" and take 2 leafs out. I don't think they make lowering leafs for burbs that year.
Can anyone tell us what they did?
Old 08-06-2009, 09:40 PM   #7
BGRAFX
Thanks for the pictures and replys. The first pic you uploaded above used a cut coil spring from an 04silverado. There aren't too many suburbans so thats why i figure the blazer guys can help. I will keep searching.
Old 08-06-2009, 09:52 PM   #8
87 dually burb
my short bus
87 dually burb's Avatar
you can 4" drop hanger in the rear
3" bell tech spindles with 2" springs
them pull a leaf or 2 if not level
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 08-06-2009, 10:38 PM   #9
BGRAFX
Thanks duallyburb, your suburban is coming together nicely. How well does it drive?
Old 08-07-2009, 09:56 PM   #10
87 dually burb
my short bus
better than stock much smoother now just have to weld in all shock tabs and finish rear floor
got 400 mile rode trip end of month
Old 08-12-2009, 05:05 PM   #11
cadpwrd
cadpwrd's Avatar
Here is a pic of my old squareburb. I used 3" spindles and the $40 ebay flip kit. I really miss this truck.
cadpwrd is offline   Reply With Quote
Old 08-13-2009, 01:38 PM   #12
BGRAFX
That's the perfect stance I was looking for. Thank you for letting me know what you used.
Old 08-13-2009, 10:55 PM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
This is my old '91 'burb.
3" drop spindles and 2" drop springs up front.
The rear was a set of 4" drop leaf springs. (Chisholm Suspension,... which is no longer in business,... I think)
Keith
Convert to disc brakes.
Old 08-15-2009, 02:14 AM   #14
Square84
I don't think these pills work
Square84's Avatar
the back is 2" belltech drop shackles and the front is 1 full coil cut off the springs
SQUARE84
90 SUBURBAN
Square84 is offline   Reply With Quote
Old 08-19-2009, 05:04 PM   #15
justpball
justpball's Avatar
yep thats mine like they said i cut some 04 coils cut 1 coil and took 2 leafs out of the back.
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
