11-17-2009, 01:24 PM | #1 |
conventional or synthetic??
i have a 91 s10 blzr with the 4.3 non vortec that was recently rebuilt bout 2k on the motor and 125k on the chassis, also an 87gmc s15 with the iron duke wit 95k. ive been using conventional in both (castrol gtx) but would synthetic better suit?? i appriciate your help
11-17-2009, 01:39 PM | #2 |
Re: conventional or synthetic??
if you start runin syn you need to be dedicated to stayin i would run it in the fresh motor and a syn blend like max life in the other just my 2 cents as i run a lube shop
1989 jimmy "U.A.V" 44/14blt 4.56s locked up 37's 1984 2wd swb 1969 swb 4x4 |
11-17-2009, 01:39 PM | #3 |
I use only conventional oil in my engines, usually castrol gtx.I don't trust synthetics at all.I'd say stick with the conventional oil .
R.I.P gm 1908-1986 1982 chevy k20,350,sm465,np205,10bolt and 14bolt s.f |
11-17-2009, 02:09 PM | #4 |
synthetic mobil one or royal purple are my 2favorites in everything trannies rears and wheel bearings too //theres a definate MPG advantage to using them and the cost difference isn't all that great anymore
11-17-2009, 03:13 PM | #5 |
On a budget like Fred Sanford
It's been proven time and time again that synthetic lubricants are superior to conventional in every way. Switch to synthetic and enjoy longer change intervals and superior protection. If you're bored and want to learn more than you ever thought possible about oil, stop by here:
http://www.bobistheoilguy.com/forums/ubbthreads.php
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
11-17-2009, 04:06 PM | #6 |
Active Member
If these are both roller motors go synthetic
If it is a flat tappit I would stick with conventional with EOS added to preserve your camshaft
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
11-17-2009, 09:21 PM | #7 |
I've run nothing but synthetics since they first came on the market. I use RP now and change oil every 15-25,000 miles and I have over a million miles on my last three vehicles. I'd say it works pretty well.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
11-17-2009, 10:35 PM | #8 |
synthetic is far better oil. using conventional oil past break in at this point is a waste. if you crack two identical engines open at 100k miles one having run conventional and the other running synthetic the difference is amazing in how much cleaner and how little wear will be in the engine that had synthetic
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-18-2009, 05:47 PM | #9 |
I run synthetic in all my vehicles,Harley included. I run schaffer 10w-40 in my `04 Impala and the same in my `70 C20 with a modified 400 small block. They both have the friction inhibitor that flat tappets need.I've never had any problems in anything. I tow a 24ft camper with the `70 and in the hills of Pa and W Virginia it gets a workout. It's just a matter of choice as almost all of todays premium oils are ok
11-18-2009, 11:49 PM | #10 |
its all about the +6 inches
11-22-2009, 05:53 PM | #11 |
If you run the mobil 1 turbo diesel truck oil that has all the zddp in it that you could ever need and its syn. good thing is that you can get it at costo or sams pretty cheap. or use the rotella t syn also a great oil. the RP and the Lucas have the zddp but they are marginally more expensive and arent available everywhere.
11-24-2009, 12:08 AM | #12 |
Still Learning
I run both I run the cheap stuff Quaker State 5W/30 in my Pontiac Grand Am and Grand prix and Full synthetic Mobil 1 in my Trucks. For the record, I had 1988 regal that had 326k documented miles when I gave it away (never turned a wrench on the engine) Ran conventional changed ever 5-7k miles.....my 1999 Burb 4x4 has 225k miles run Mobil1 only change the oil every 12k miles. Both will give you long life more a matter of the newer engine design. They oil a lot better and the roller design gets more oil to the top end.
