11-02-2009, 09:25 PM | #1 |
Torn between 66 and 78
84 3/4 truck parts that are usable for a 66?
My buddy has a 3/4 ton '84 at his buddys house. He told me I can go over there and take what I need from it. Now, I want to grab the lower control arms, spindles, calipers, power steering box, ps pump, ps hoses, idler arm, and the distributor. Brake booster is all ready gone
My questions to you are: Will my list of grabs work on our trucks? Anything else that would be a worthwhile swap for our trucks? The truck is a 8-lug, can I buy 6-lug rotors for them and slap them on that spindle? Am I forgetting something? Any help and opinions are appreciated. Thanks. |
11-02-2009, 10:30 PM | #2 |
Re: 84 3/4 truck parts that are usable for a 66?
I am pretty sure that the 3/4 ton spindles are different, the steering box will work with an adaptor
11-02-2009, 10:50 PM | #3 |
I have heard and read that we can use 73-87 lower control arms for disc brake swaps. If we can't use the spindles, which ones would you use than?
11-02-2009, 11:20 PM | #4 | |
Jonny
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
11-02-2009, 11:34 PM | #5 |
It does. But, I thought I have read that the upper control arms are the same from 6x or so, thru 87??????
11-03-2009, 01:01 AM | #6 |
OK, after reading a ton of threads (again), I think I have the front figured out the front disc swap for 6 lug discs. Hre is what I came up with.
66 1/2 ton UCA. Change LCA to 3/4 ton from the 84. Get Spindles, Calipers, Upper and Lower ball joints, Outer Tierods; 1 1/4" 6 lug rotors; all from 88 & up. Now, what parts do i need to upgrade to the power steering from the 84? Last edited by CSoliz; 11-03-2009 at 01:02 AM. |
11-03-2009, 01:03 AM | #7 |
6X-72 have the threaded rubber-lined steel sleeve bushing. 73-87 have the press-fit rubber bushing (no steel sleeve). BJ's interchange on 6X-87 uppers so you just need the correct BJ for the spindle & it can be bolted on to any upper a-arm within those model years.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-03-2009 at 01:03 AM. |
11-03-2009, 02:07 AM | #8 | |
60-66 Nut
The 6 lug rotors you need are for the 7200GVW 2500 series. IIRC the '88 & '89 are one part number and the '90 + are a different number. The spindles can be the from 1500 with the 1.250 rotors or the 7200GVW 2500. You will need some different inner tierods also, the ES2020's
As for the steering box, I sell the adapter plates. See the link in my sig. Quote:
11-03-2009, 09:08 PM | #9 | ||
Would it be wise just to take the whole steering assembly off the 84' or do I just need the pitman and idler arm? Or are they the same as the 66'? |
11-04-2009, 01:12 AM | #10 | |
60-66 Nut
Yes that is correct. The 7200GVW is the light duty 2500 series (3/4 ton) which have the 6 lug discs in a 2wd version
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 11-04-2009 at 01:13 AM. |
11-15-2009, 11:04 PM | #11 |
another option is you can remove the complete front crossmember from the frame as a complete assemby with suspension. and it will bolt right up under your pick up. then you have the complete new suspension and steering. you only have to mount the steering gear and idler arm to the frame. This is alot easier with the engine removed because the engine mounts are bolted to this crossmember also.
71 GMC Long Bed, 454,factory everything, lowered, and shaved. 64 GMC Short Bed (great grandfathers truck) 65 Chevy 1 ton Dually a/c p/s p/b v8 auto 89 Jeep Cherokee 3" lift 79 MG Midget (My 7 year old vehicle) 29 Ford Model A Rat Rod (in the works) 86 pontiac fiero 2.5 manual18 year olds) 87 pontiac fiero SE 2.8 auto (18 year olds) 90 Mitsubishi eclipes turbo AWD (18 year olds) 69 BMW 1600 (wifes toy) |
12-24-2009, 04:47 PM | #12 |
ok, one more question. I have 63-72 3" lowering springs for the front. If I was to swap to the 3/4 front end, would I still be able to use these springs?
Thanks. |
12-24-2009, 04:59 PM | #13 | |
(62gmc910) I didn't notice that my son was signed in
65 gmc 930 292 4speed 700-18 duals 39k all original 65 chevy 10 long fleet parts truck 63 gmc 950 camperized bus 350 4spd 2spd axle 64 gmc 950 spare bus 53 gmc 1ton dual bus 79 gmc c20 short course offroad race truck 355 th400(www.wheel2wheel.ca) |
