Old 03-14-2010, 07:01 PM   #1
orange70350
orange70350's Avatar
starter problems help
i have a 70 chevy with a 350. i replaced the starter and now i have no to power to anything. what color wires go to which termanals on the starter?
orange70350 is offline   Reply With Quote
Old 03-14-2010, 07:52 PM   #2
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Re: starter problems help
So when you turn on the key nothing happens? Headlights dont work either? If the answer is yes to both you either are missing the battery ground or does yours have a positive coming off the battery that goes to the terminal stud on the fender? That could be interupted.
Ill check on the wiring, but the purple should be coming from the ignition switch, yellow(if your still using points) goes to the R terminal, and Big red to the post from the battery.
Just checked, Purple goes to the S terminal, Yellow goes to the R.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 03-14-2010, 08:02 PM   #3
orange70350
yea to all i am still running points and it had a wire going to a stud on the fender but there was never anything on the other side of the termanal. i do have 2 wirers hanging neer the battery one is red and the other a brown fused wire. i dont know if that has anything to do with it or not. the PO was not a wiring pro to sat the least.
Old 03-14-2010, 08:11 PM   #4
71meangreenc10
those two wires need to be hooked up to the + bat side. Try that and see what happens.
Smitty
71 C30 Wrecker
Old 03-14-2010, 08:16 PM   #5
71meangreenc10
The red one is REALLY important....
Smitty
71 C30 Wrecker
Old 03-14-2010, 08:16 PM   #6
orange70350
will do thanks guys for the info. ill try it after work tomarrow now that its dark out and the fuse in the brown wire is broken and i dont have a replacement and what are the functions of the wires in question?
Old 03-14-2010, 08:32 PM   #7
71meangreenc10
the red one provides power to everthing, the brown one is the fuseable link to send power to the red one.
You could just hook up the red one for now to make sure everything works, but i would put in the link with the fender terminal.
Unhook the ground first though.
Smitty
71 C30 Wrecker
Old 03-15-2010, 08:07 PM   #8
orange70350
thanks meangreen! that was my problem. but note to self dont try to start the truck again until i have something on the other sside of the headers
