03-26-2010, 12:07 PM | #1 |
SBC 327 Compression
What (In PSI) Should the compression be of a 60's corvette 327 engine be. I am getting anywhere from 120-135 psi.
1972 longbed- 454 1967 shortbed- 355 |
03-26-2010, 03:14 PM | #2 |
Re: SBC 327 Compression
I think it's more about the consistently of the compression levels between the cylinders. If you're getting a +/- 7 psi spread @ ~125 psi, I think you're ok.
03-27-2010, 02:34 PM | #3 |
this is what I had when I first checked mine the first month i bought it, (68 327)
1 - 160 2 - 165 3 - 165 4 - 170 5 - 170 6 - 165 7 - 170 8 - 160 as stated above, its more important to note separation between cylinders than anything, many things can vary how "MUCH" compression you have. GL, |
03-27-2010, 03:08 PM | #4 |
Compression ratio and camshaft can greatly affect compression test numbers. Generally 125 is showing a worn engine but its evenly worn and I wouldnt worry about getting a good bit more mileage out of it. If your looking to do upgrades such as new heads or a cam swap for more performance etc. I would wait until you can do a full rebuild. A lot of those 60' engines were above 10-1 compression which should definately show more than what your getting. Im not saying the engine is worn out but I wouldnt be doing performance upgrades or be out beating on it.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
