Old 02-07-2003, 12:46 PM   #1
Yukon Jack
Yukon Jack's Avatar
Rope gasket on transmission floor hump
When I pulled the transmission floor hump I found a rope type gasket that is completely oil soaked.
Is this a part that is available, or should I just buy some similar sized rope and use that?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-07-2003, 01:07 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Call me a brute, but I just used some smurf goo on mine. (Silicone)
Old 02-07-2003, 01:09 PM   #3
mrein3
mrein3's Avatar
I just used the 3M black tar-like calk (sp?) strips my HVAC buddy gave me. I think they use it to seal up combustion chambers on forced air furnaces.
It was a bear to get to stick right but I wouldn't go without something to seal it up.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 02-07-2003, 01:23 PM   #4
lpaine
lpaine's Avatar
rope gasket
Yukon Jack I've been kind of wonderiing about this myself as I am planning to switch my truck over to a standard trans with high hump. I looked at the factory assembly manual, and it isn't much help, although it does mention sealing compound (5/16"bead) for attaching the hump to the floor, I seem to remember someone on here mentioning how to do this some time ago. You should have your answer before sundown anyway. I'll be watching for this one too. lpaine
1969 G.M.C 3/4 Ton 920 (Canadian Version) 307 3 speed, currently apart
1998 Chevy 1/2 ton ex cab V-6 5 speed
1967 Chevy SWB - project truck; not started just yet
lpaine is offline   Reply With Quote
Old 02-07-2003, 01:25 PM   #5
JimKshortstep4x4
Talking
We glue the round rubber strip material like is used on the metal door panels using 3M trim Cement. Clamps are used to hold the rubber in place while it drys. Before installing we put the strip caulk in place,(3M) and install the hump.
Jim
